I think you're confusing power levels with the channels/frequencies.
The power levels are adjustable at the green boxes where there are different attenuators/boosters to hook your cable onto depending on how far away your house is etc.
The ideal power level is 0 but -3 to +7dB is generally recommended by Virgin I think, the power level will fluctuate under different temperatures so it's impossible to have bang on 0dB all of the time. I think the DOCSIS specification for most modems is +/- 15dB but you might get problems at either extreme.
no. every engineer that has came out to me has said different areas have different power level ranges. maybe it's another lie from the engineers
Still might be some differences with the old Telewest and NTL regions but obviously have to be within DOCSIS spec.
Sure thing
The engineer has just been and adjusted the levels. Here's what it looks like now:
A much better result!
I will keep an eye on it over the next few weeks and see if the high latency issue returns.
thanks for the update. Have posted over on the VM forums as i won't be able to call until the weekend, over the past 2 days i have had to reboot the SH several times and now my 120Mb has dropped to around 30Mb - 40Mb... plus side had an email from ocuk saying my asus rt n66u (RMA) will be delivered tomorrow so wireless will be much better
