** FAO: MINERS - COME ON IF YOU THINK YOU'RE HARD ENOUGH!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Reports world wide about 280X being sold out, nowhere in the UK with stock, or just 1-2pc not worth talking about.
http://www.extremetech.com/computin...e-in-litecoin-mining-leads-to-radeon-shortage
http://www.slashgear.com/litecoin-mining-gpu-sales-spike-following-bitcoin-value-drop-off-14308854/
Yet throughout this OcUK has never being without stock!!
Well miners out there, I've got 1000 UNITS IN STOCK, well I did have this morning, they are selling quick, so I've got the stock, NOW GET YOUR WALLETS OUT:-
Asus Radeon R9 280X DirectCUII TOP 3072MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
The next generation Asus R9 280X DC2T graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1070MHz
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6400MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 3yr Warranty
Only £275.99 inc VAT - OVER 100 IN STOCK!
ORDER NOW
Gigabyte Radeon R9 280X Rev2.0 WindForce 3X OC 3072MB GDDR5 PCI-Express Graphics Card with Battlefield 4 PC Game @ £259.99 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
Specification:-
- Rev2.0
- Black PCB
- Core Clock Speed: 1000MHz
- Boost Clock Speed: 1100MHz
- Memory Width / Speed: 384 bit / 6000MHz
- Display Outputs: 1x DVI + 2x Mini-DP + 1x HDMI
- Power: 250W TDP
- 3yr Warranty
Only £259.99 inc VAT - OVER 100 IN STOCK - THIS PRICE ENDS SOON!!
ORDER NOW
MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
Only £275.99 inc VAT - 100 IN STOCK!
ORDER NOW
Powercolor Radeon R9 280X 3072MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
Powercolor R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Equipped with a near silent cooling solution meaning you can game in near silence.
Specification:-
- Core Clock Speed: 850MHz
- Boost Clock Speed: 1000MHz
- Power: 250W TDP
- 2yr Warranty
Only £259.99 inc VAT - 50 IN STOCK!!
ORDER NOW
Sapphire Radeon R9 280X Dual-X OC 3072MB GDDR5 PCI-Express Card with Battlefield 4 PC Game @ £269.99 inc VAT
The "dual" in Dual-X refers to the two highly advanced cooling fans that are coupled with multi-heatpipe technology to cool mid-to high-end graphics cards. The fans are amazing: each blade boasts a sleek airfoil shape that increases cool air throughput so they can run slower. Even when you're pushing the processing power to the limits. Even when your're overclocking.
The quiet-running fans work with multi-heatpipes and heatsinks that take away heat from the processor to the fans. Plus, dust repelling bearings radically reduce failure caused by the build-up of dirt. In short, its a quiet, efficient way of cooling your graphics card - even when you're pushing it to the limits.
Specification:-
- Core Clock Speed: 870MHz
- Boost Clock Speed: 1020MHz
- Power: 250W TDP
- 2yr Warranty
Only £269.99 inc VAT - OVER 100 IN STOCK!
ORDER NOW
Sapphire Radeon R9 280X Vapor-X OC 3072MB GDDR5 PCI-Express Card @ £275.99 inc VAT
High-end graphics card use more power, which means they get hotter quicker. With the innovative Vapor-X, we were the very first to apply aerospace-industry vapor chamber technology to graphics cards. It's a pioneering way to accelerate heat away from the graphics chips into the rest of the cooling system.
Sapphire Vapor-X technology is used in conjunction with a heatpipe and fan assembly. The vapor chamber accelerates the heat away from the graphics chips into the rest of the cooling system. How? Inside the vapor chamber, a liquid coolant is vaporized at the hot surface. The resulting vapor moves across the chamber where it condenses at a cooled surface. Then the liquid is returned to the hot surface to aid in superior cooling.
Features:-
- 2nd generation Vapor-X technology
- Factory overclocked
- Quiet and efficient cooling
- UEFI support
Specification:-
- Core Clock Speed: 950MHz
- Boost Clock Speed: 1070MHz
- Memory Width / Speed: 384 bit / 6200MHz
- Power: 250W TDP
- 2yr Warranty
Only £275.99 inc VAT - OVER 100 IN STOCK!!
ORDER NOW
Sapphire Radeon R9 280X Toxic OC 3072MB GDDR5 PCI-Express Card @ £319.99 inc VAT
The SAPPHIRE R9 280X TOXIC features SAPPHIRE Vapor-X technology which is a sophisticated integration of digital power IC, DirectFet, and four new Black Diamond heatsink chokes on a high density 10 layer PCB. This technology is capable of supplying 60 Amps power per phase on demand, which is 20 Amps more than the HD 7970 reference design. With a suitable PSU! Compared to the reference board, Sapphire's Vapor-X technology provides more headroom for overclocking with a power efficiency of over 90%. Sapphire provides efficient power whenever the GPU needs it.
The new Tri-X cooling technology is a combination of the optimized cooler module, new 10mm heatpipe and Triple fan. As a result, the new cooler is 20% quieter than the previous Toxic HD 7970 GHz Edtion.
Key Features:-
- Triple Fan cooler, 30% more airflow and 20% quieter than the previous Toxic HD 7970 6GB card.
- Optimize dual module design, the new fin and heatpipe placement improves the airflow offer 50% more efficiency in heat dissipation.
- Anti-Dust bearing, Enhance the reliability for the fan cooler.
- Memory cooling, the cooler module also cools the memory chip for the best stability and offers more OC headroom.
- Sapphire Power and Temperature LED indicator
- Dual Firmware: UEFI & BIOS
- Sapphire Black Diamond Chokes
- Digital Power 8+2+2 Phase
- Support upto 4 monitors
Specification:-
- Core Clock Speed: 1100MHz
- Boost Clock Speed: 1150MHz
- Power Connectors: 8-pin + 8-pin
- Display Outputs: 2x DVI + 2x Mini-DP + 1x HDMI
- Power: 250W TDP
- Dimensions: 308(L)x113(W)x41mm
- Product Review: http://www.kitguru.net/components/graphic-cards/zardon/sapphire-r9-280x-toxic-edition-oc-3gb-review/
- Product Review: http://www.anandtech.com/show/7406/the-sapphire-r9-280x-toxic-review
- 2yr Warranty
Only £319.99 inc VAT - 50 IN STOCK!!
ORDER NOW
Asus Radeon R9 290 "Voltage Unlocked" 4096MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
nonl2br
<p align="left">
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
</p>
<br />
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/6z-Z31pvRRE?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="false"></param><param name="allowscriptaccess" value="always"></param>
<embed src="//www.youtube.com/v/6z-Z31pvRRE?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="false"></embed></object>
</center>
<br />
<br />
<p align="left">
<h1>Specification</h1>
<b>Radeon R9 290</b> <br />
- GPU: Hawaii Pro <br />
- Stream Processors: 2560 <br />
- Core Speed: 947MHz <br />
- Memory Speed: 5000Mhz <br />
- Memory interface: 512-Bit <br />
- Memory capacity: 4096MB GDDR5 <br />
- Cooling: 2-Slot Blower Fan <br />
- PCI-Express X16 lane required <br />
- 750W or greater PSU required <br />
- Power Connectors: 8-pin + 6-pin required <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
</p>
<p align="left">
<b>Features</b><br />
- DirectX 11.2 Support <br />
- Open GL 4.2 Support <br />
- Dolby TrueHD and DTS-HD Master Audio support <br />
- Crossfire Support upto 4-way: Native software crossfire (No bridge required) <br />
- Gaming @ 4k Resolutions (UltraHD) <br />
- Synergy with next-gen game consoles (Mantle) <br />
- Graphics Core Next (GCN) architecture - optimized from previous generation products
</p>
Only £359.99 inc VAT - 100 IN STOCK!!
ORDER NOW
Asus Radeon R9 290X 4096MB GDDR5 PCI-Express Graphics Card @ £429.95 inc VAT
nonl2br
<p align="left">
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
</p>
<br />
<center>
</center>
<br />
<br />
<p align="left">
<b>Radeon R9 290X</b> <br />
- GPU: Hawaii XT <br />
- Stream Processors: 2816 <br />
- ROPS: 64 <br />
- Core Speed: 1000MHz <br />
- Fan Speed: 20% - 40% (Quiet Mode) & 20%-55% (Uber Mode) <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort <br />
- Warranty: 3yr
</p>
<p align="left">
- DirectX 11.2 Support<br />
- Open GL 4.2 Support<br />
- Dolby TrueHD and DTS-HD Master Audio support<br />
- Crossfire Support upto 4-way: Native software crossfire (No bridge required)<br />
- Gaming @ 4k Resolutions (UltraHD)<br />
- Synergy with next-gen game consoles (Mantle)<br />
</p>
Only £429.95 inc VAT - 50 IN STOCK!!
ORDER NOW
Sapphire Radeon R9 290 4096MB GDDR5 PCI-Express Graphics Card @ £335.99 inc VAT
nonl2br
<p align="left">
</p>
<br />
<center>
</center>
<br />
<br />
<p align="left">
- Warranty: 2yr
</p>
<p align="left">
</p>
Only £335.99 inc VAT - OVER 100 IN STOCK!!
ORDER NOW
Sapphire Radeon R9 290X "BF4 Edition" 4096MB GDDR5 PCI-Express Graphics Card (21226-00-53G) @ £467.99 inc VAT
nonl2br
<p align="left">
</p>
<br />
<center>
</center>
<br />
<br />
<p align="left">
- ROPS: 64 <br />
- Comes with BF4 Voucher included in the box <br />
- Warranty: 2yr
</p>
<p align="left">
</p>
Only £467.99 inc VAT - OVER 100 IN STOCK!!
ORDER NOW
Sapphire Radeon R9 270X Vapor-X OC 2048MB GDDR5 PCI-Express Card @ £169.99 inc VAT
Features:-
- UEFI support
Specification:-
- Core Clock Speed: 1050MHz
- Core Boost Speed: 1100MHz
- Stream Processors: 1280
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5800MHz
- Power Connectors: 6-pin + 6-pin
- Power: 180W TDP
- 2yr Warranty
- Exclusively ONLY at OcUK we also give you BF4 with this card
Only £169.99 inc VAT - OVER 100 IN STOCK!!
ORDER NOW
No shortage here at OcUK, Newegg, maybe you should get in touch, we do offer trade pricing. ;)
I will be buying a GPU end of this week. If only the 280x were closer to the £200 i would pick up one without thinking twice! I would rather pay that price and not get the game bundle as i never been able to sell them even on ''auction sites'' - atm im learning towards the 270x
Pushing the "mining" so much is slightly diminishing my respect for OCUK if I'm honest. Bit like Estate agents ramping up the price of property.
:confused:
Bought two of those ASUS 280X couple of weeks ago, happily mining at 750Kh each. If i count the second hand value of the cards i've already made my money back :D
Gotta agree to be honest, been mining for around a year (and help with a pool) now so been through the hoops.
Kinda reminds me of shuttup and take my money, except the only winners are OcUK :P
There's gonna be a lot of amateurs selling their stuff on ebay in a month or two.
I dunno, OcUK win because of massive sales as do AMD. People buying cards to mine with and game on win because they get cheaper / free cards. People buying all the 2nd hand cards in a few months win because prices should be pretty low if the market gets flooded.
