I had a corsair 200r which have similar fan setup and also had a problem with fan placement.
Eventuallt I bought a small and strong fan, it was a 40mm i think, and installed it between the cards, blowing air thru the space between them. Helped a bit but not that much. Problem is most of those little fans are noisy so not an optimal option.
To be honest, watercooling is the only advice I could give you which is going to work for sure.
