New Build £1900 To spend!
Change the PSU! It's not a very good OEM and is very expensive for what it's worth.
Flextronics isn't actually a bad OEM, there are worst out there like the other OEM's Thermaltake's TP-1000M what uses Enhance Electronics as its OEM.
The non (i) would be my first choice as well chaps but as its now getting a bit long in the tooth its getting hard to source the braided cables these days (Remember the Flextronics units use different cables to the Seasonic PSU's).
Extensions could be the answer if you wanted to use a non Corsair PSU but in these mATX builds they can be a nightmare to do a decent cable management job unless you know what your doing.
It in-line with the epic Corsair and Micro Star International black and red theme that is running though out my spec :D:p
OR if you wanted to do something a bit different hows this :p
Your cable management skill will have to be right out of the top draw and I would ask pexonpcs to braid all the cables in black.
YOUR BASKET
1 x Asus SonicMaster MX299Q 29" Ultra Widescreen Ultra Slim Bezel LED Monitor - Black with Bang & Olufsen ICEpower Speakers £399.95
1 x Gigabyte Radeon R9 290 OC WindForce 4096MB GDDR5 PCI-Express Graphics Card (GV-R929OC-4GD) £389.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £263.99
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard £152.99
1 x In-Win 904 Mid Tower Case - Silver £149.99
1 x Corsair Vengeance K70 Mechanical Gaming Keyboard – Silver - Red Switch (CH-9000019-UK) £119.99
1 x Corsair Dominator PLATINUM 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit with DHX Pro Connector (CMD8GX3M2A1866C9) £119.99
1 x Be Quiet Power Zone 750W '80 Plus Bronze' Fully Modular Power Supply £99.95
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £79.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £71.99
1 x Corsair Hydro H90 140mm High Performance Liquid CPU Cooler (CW-9060013-WW) £69.98
1 x Corsair Vengeance M65 Laser Gaming Mouse - Black (CH-9000022-EU) £54.95
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x BitFenix Alchemy Premium Modding LED Strip - Aqua White 50cm £29.99
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
3 x Alpenföhn 140mm Wing Boost Plus PWM Fan - Orange £14.99 (£44.97)
1 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Black £4.99
Total : £2,146.30 (includes shipping : £22.20).
Oh Jesus Christ, get rid of that case and then throw it under a bus Ethermaster. :p
NOBODY should EVER buy one. EVER. :rolleyes:
If your friend is studying at a collage / university who is registered for 'microsoft dreamspark' program then he could get windows 7 / 8 for free, might be work a look then he'd have a few extra quid for the computer....
thanks
stu
Or you can get it cheaper just for being or knowing a student too.
