- 2 Jan 2012
- UK.
ASUS’s upcoming Radeon R9 290X DirectCU II OC graphic cards has been leaked Sweclockers ahead of its launch scheduled for January 2014. The ASUS Radeon R9 290X DirectCU II OC ships with a factory overclock and custom PCB design which will leverage its performance over the reference boards and help improve the cooling capability of the graphic card.
ASUS Radeon R9 290X DirectCU II OC With 1050 MHz Clock
The ASUS Radeon R9 290X DirectCU II is an overclocked edition card hence it ships with a factory overclock out of box. From a technical perspective, we are looking at the default 2816 Stream processors, 176 Texture mapping units, 64 Render Backends and a 4 GB GDDR5 memory operating across a 512-bit interface. The clocks have been configured at 1050 MHz for the core and the memory runs at 1350 MHz (5.4 GHz effective) which is upped from its default state of 1000 MHz core and 1250 MHz (5.0 GHz effective) clock speeds.
Read more: http://wccftech.com/asus-radeon-r9-...cked-1050-mhz-red-gold-flavors/#ixzz2ngUVTHC8
Read more: http://wccftech.com/asus-radeon-r9-...cked-1050-mhz-red-gold-flavors/#ixzz2ngUP4VG5
