i7 4770k
Water won't necessarily let you clock it higher, it will however let you increase voltage more than you would on air by keeping temps down. What vcore are you running x44 with?
If you know how to overclock then there is honestly no point in buying a pre overclocked bundle. Buy seperately and you'll save £50-100.
The premium is for the OC.
Got the 4770k. Currently prime 95 testing.
4600Mhz.
Vcore = 1.37v
cache = 4500Mhz
cache volts =1.35v
Was passing every other benchmark with greatly reduced volts but this is prime 95 stable. Temps are 54 or below.
Crashed after a few hours.
4600Mhz.
Vcore = 1.38v
cache = 4500Mhz
cache volts =1.35v
Analog IO volts = 150mV
Digital IO volts = 150mV
One hour stable in prime 95. Temps hitting 64 max. Processor input voltage at 1.95v. Fixed Ram timings. I added 8GB of Ram.
New processor and testing in aida 64, at 1:1 x45.
vcore 1.35volts water cooled approx. 60oC full load.
Cache volts 1.4volts. 3 hours stable so far.
