Hi all,
I've decided to get into overclocking again with my new rig, having moved from Sandybridge to Haswell I'm a bit of a noob again as Haswell requires a bit more fine tuning in the BIOS to gain a stable overclock as you all will know. Anyway, I'm overclocking with the Gigabyte Z87-D3HP motherboard and my ram is the TeamGroup Vulcan 8GB 2400Mhz version.
Currently I've got the ram set to Profile1 on the XMP which allows it to run at the full 2400mhz @ 1.65V and the auto set RAM timings are 11-13-13-35 (command rate 2T). As expected the system runs fully stable with these settings but do these still look ok to be able to help support a stable CPU overclock?
I've had a little play about the last couple of days and I've also read some of the Haswell overclocking guide over on the overclock.net forum. Anyway, these are the settings that I've adjusted in my BIOS to test a 4.4Ghz overclock on my 4670K:
CPU VRIN Override LLC: Extreme
CPU VRIN Override Voltage: 1.7V
VCore: 1.25V
Ring Voltage: 1.15V
CPU Multiplier: 4400
C1E, C3, C6/C7, and EIST: All disabled
I originally had the Vcore set at the starting 1.24V mark and AIDA64 was runinng fine up until the 13 minute mark when I decided to open up Firefox and then the system BSOD with the 124 error (not enough Vcore by the look of it) and so I upped it to 1.25V before I stopped there to post in here.
How do my posted settings currently look? Do I need to make anymore adjustments in the BIOS to gain stability? Also, I want the CPU to downgrade the clock/voltage during idle and I know that one of those power saving settings need to be re-enabled, but which one is it?
Lastly, while AIDA64 was running on the first test - the CPU maxed out at 81c at some point with it averaging at 75c ish most of the time and I'm using the Prolimatech Panther cooler. Bearing in mind that I've heard that Ivybridge & Haswell's now run much hotter than Sandybridge's but do my temps look normal?
Many thanks
Liam
VCore: 1.25V
Ring Voltage: 1.15V
Many thanks
Liam
I'm still in the testing stages with mine to see if it's stable with 4.4Ghz on 1.26v!
