CM Storm Quickfire TK Mechanical Keyboard Review
Caporegime
4 Jun 2009
Features:
  • N-Key Rollover
  • Easy cable management
  • Full red LED backlight, 3 modes and 5 brightness levels
  • Compact Layout with integrated NumPad block
  • Red switches
  • Detachable braided USB cable
For more info. on this keyboard, visit here.
There aren’t an awful lot of features on this keyboard compared to most other keyboards i.e. no macro keys, no “dedicated” media controls, no fancy screen like other more expensive keyboards. It is just a simple mechanical keyboard with “FN” keys and red back lighting, however, crafted to a very high standard.
Packaging:
The packaging is nice and minimal with the box not being any bigger than required. As usual, you have all the standard info. on the back and sides.
Along with the USB cable and keyboard, we also get a keycap puller & info. sheet.
Installation:
Couldn’t be any simpler! No drivers or software are required, simply plug into a spare USB slot and you can start typing straight away.
Build Quality & Aesthetics:
Overall this keyboard is extremely solid, no flex at all! The build quality alone is worth £70! All my previous keyboards had nasty creak noises, gaps, lose plastic etc. but this CM storm keyboard is built like a tank!
Even the USB cable feels solid, it is braided and has a nice length to it, 1.8m.
Overall this keyboard is superb looking, it is compact and minimal looking and once you turn the back lighting on, it just looks even better. The back lighting is perfectly even throughout the keys/gaps unlike my old saitek eclipse II……. The effect of the red back light is made even better since the back plate is red.
Unfortunately my camera doesn’t do this keyboard any justice especially with regards to the red back lighting…..
On the back of the keyboard you have cable routes and two rubber feet that can extend the keyboard height/angle when clipped out.
The weight to the keyboard is just superb too, not too light and not too heavy, it weighs in at 544g.
This keyboard doesn’t have any dedicated media controls but it does have “FN” keys so F1-F12 can be used for things such as; mute, next/previous track, volume control, windows start button lock + control the back lighting; 5 different brightness levels + 3 different modes (pulse, WASD only, entire keyboard)
One very unique thing about this keyboard is that it is a TK (Ten keyless) keyboard, however, it still retains the NumPad and command keys i.e. home, end, pg down/end, scroll lock, it is cleverly done via the num lock key so when the num lock is activated you can use the numbers + enter key etc. and when num lock is disabled you can use the arrow keys + print screen, screen lock etc. keys. If you are someone who is use to the full keyboard layout + uses both functions a lot, this keyboard may not be for you, however, you eventually get used to it, granted it is a bit of a pain having to switch from one mode to the other especially if you are programming for example.
If you are someone that attends a lot of LAN events, I couldn’t think of a better keyboard to bring.
Key quality:
This is the most important area when getting a new keyboard and after many months of trying to decide between a Corsair K30 membrane keyboard and a £70 mechanical keyboard, I can without a doubt say that this keyboard is easily worth £70 with regards to this area. I went with the red switches over the brown, black, blue switches for a few reasons; lighter/easier to activate & no click noise.
In terms of noise, mechanical is a fair bit louder than membrane keyboards (I imagine that the other switches will be more noisy than red switches due to the click noise), however, only when you fully bottom out, once you get use to how light the switches are, you can type more quietly than you do on a membrane keyboard. In terms of what sounds better, this cm storm keyboard sounds a lot nicer than the other membrane keyboards in the household.
The sound can be further reduced by using o-rings.
Since switching to this keyboard, the best advantage of red switches/mechanical is that my fingers no longer get cramped/tired after long hours of gaming on BF 4 and as a result I can play at a higher standard for longer. I also feel that I type quicker and more accurately too.
Overall mechanical feels more responsive, I mainly noticed it when flying helis in BF 4 (I use WASD + arrow keys), but not enough to be worth worrying about.
For more info. On the different types of mechanical switches, have a read through this thread.
Onto the quality of the key caps coat/finish, the keys have a nice soft grip touch to them and feel better than the majority of key caps on other keyboards, my only complaint is that they get grubby and show some smear marks after a week or two of medium usage. Thankfully it is easy to clean the key caps though.
Conclusion:
Overall I couldn’t be happier! It took me months to decide on a keyboard, mainly if it was worth spending another £30-40, I did so much research and you had two camps when it came to mechanical; people who say it isn’t worth it and those who say that they couldn’t go back, worth every single penny and needless to say, I am part of the latter group now. Membrane keyboards just don’t feel as responsive, nice to use and key feedback is poor in comparison, especially when they start to wear out.
As for what mechanical switch suits you best, it is personal preference, have a read through some forums/guides as linked above and watch videos comparing the switches. The CM storm Quickfire TK also comes with brown and blue switches too.
Whilst the CM storm quickfire TK is one of the cheapest mechanical keyboards on the market, it most certainly does not give that impression from my experience.
Pros:
  • Build quality couldn’t be better
  • Keyboard is extremely nice looking especially with the red back lighting
  • Red switches are a pleasure to type and game on, easy to activate
  • Very compact whilst still retaining the command keys plus numpad
Cons:
  • Key caps can get grubby/smeared quite easily
Very nice review, thanks for taking the time to do it. I'm still wanting to get a mech keyboard but money is too tight now unfortunately. I'll definitely consider this one on the basis of this.
Good review,
I had the same dilema K30 or this and I chose the K30. Couldn't be happier with it.
If/when I do go mech I wil probs get a CM.
Josh
Really good review.
I have the CM Storm Quickfire Pro and couldn't be happier. :) Would definitely recommend CM for mechanical keyboard.
good review.
i would also recommend the coolermaster keyboards. the customer service is also outstanding.
i had the coolermaster QFR w/black switches but it developed a fault so coolermaster sent me one of these TK's as a replacement w/red switches. (not having to send the old one back) as much as its a nice keyboard i cant seem to get used to the reds after having blacks.
think i will be picking up another QFR soon with blacks again and then ill relegate the TK to work.
here is my TK
Nice review mate, glad you are happy with your purchase - they really are worth that bit extra in the long run.
Out of interest, have you tried the o-rings yet? I would definitely recommend them (I started off using them on just the WASD keys because I was feeling lazy, but quickly switched the lot over!)
Thanks! :)
Good to hear about CM's customer service Joel, I was really wanting to move to a logitech keyboard purely because of their superb CS but unfortunately none of their keyboards suited my requirements.
Your K/B is looking good there! Think I might swap out the WASD + arrow keys for different coloured key caps at some point, spice things up a little! :p
No not yet, I was going to buy some at the same time as the KB but thought I would see how I got along without them first and now I don't really find the need to since I am used to red switches so I'm typing pretty quietly atm :D
Will buy OcUK's o-rings when they are on offer though, £5 is too expensive considering what they are :p :o
