** GREAT PSU DEALS: INCLUDING HIGH WATTAGE MODELS FOR MINERS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some great PSU deals:-
Be Quiet Power Zone 850W '80 Plus Bronze' Fully Modular Power Supply @ £99.95 inc VAT
Important new product for be quiet! Very nice range of PSU featuring a fully modular cable design, Cool-Down period of 3 minutes so the fans continue after shutdown to ensure proper cooling of components and to reduce damage, new Silent Wings 135mm 6-pole quiet fan and a 5 year warranty.. not to mention the design is very nice indeed for a PSU and definitely sets it apart from the competition. The best bit is the price on these units are the lowest for ANY fully modular PSU range and also are the quietest..also 5yr warranty.
Features:-
- Massive 12V rail design is ideal for overclocking
- Full cable management supports maximum build flexibility
- COOL*OFF feature run fans for three minutes after system shutdown
- Connect up to three case fans for optimized system cooling
- Designed for powerful operation even at 50‹ C
- 135mm SilentWingsR fan with innovative 6-pole motor enables quiet operation
- 80PLUS Bronze efficiency (up to 90%)
- Up to six PCI express connectors (NVIDIA SLI, AMD CrossFireX)
- Compatible with Intel C6/C7
- Five-year warranty
- German product conception, design and quality control
Was [£119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Be Quiet PowerZone 1000W '80 Plus Bronze' Fully Modular Power Supply @ £149.99 inc VAT
Features:-
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
EVGA SuperNova 1000W '80 Plus Platinum' Modular Power Supply (220-P2-1000-XR) @ £185.99 inc VAT
EVGA adds a platinum series power supply to its full line with the SuperNOVA 1000 P2. This Power supply is 80 PLUS Platinum rated with an efficiency of 92% under typical loads. The new ECO Thermal Control Fan System offers Fan RPM modes to provide zero fan noise during low load operations. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. Backed by a 10 year warranty, gain peace of mind from the heart of your system and power up with the EVGA SuperNOVA 1000 P2!
Features:-
- Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
- 80 PLUS Gold certified, with up to 90% efficiency under typical loads
- Highest quality Japanese brand capacitors ensure long-term reliability
- Fully Modular to reduce clutter and improve airflow
- NVIDIA SLI Certified
- Sanyo Denki Ball Bearing fan for exceptional reliability and quiet operation
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
Was [£199.99] Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
EVGA SuperNova G2 1000W '80 Plus Gold' Modular Power Supply @ £139.99 inc VAT
The EVGA SuperNOVA 1000 G2 has arrived! This power supply is 80 Plus Gold Rated, offers 1000W of continuous power, exceptional efficiency and is fully modular. Not to mention, a first class 10 Year EVGA Warranty. Designed with enthusiast needs in mind the EVGA SuperNOVA 1000 G2 power supply is the best choice to power this and next generation enthusiast computers. Take your system to the next level and power up with the EVGA SuperNOVA 1000 G2!
NOTE: For power supplies purchased in Europe, a European style power cable will be provided.
Features:-
Was [£161.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
NZXT Hale Power 90+ 1000W '80 Plus Gold' Modular Power Supply @ £149.99 inc VAT
NZXT introduces the 80+ gold certified HALE90 series built from the ground up specifically customized for gamers and enthusiasts and offers incredibly efficient operation that will meet the needs of even the most power hungry enthusiasts.
• 80+ Gold certified: The HALE 90 series from NZXT operates at ultra high efficiency, at 20%, 50% and 100% loads, efficiencies are 87%, 90%, and 87% respectively.
• Single140mm two ball-bearing fan operates with minimal noise even at full load. Maximum decibel levels are 20db for wattages between 550-750W and 30db for 850W and above.
• Strong Single Rail Design: A single +12V rail provides stability and ease of use making the most out of your power supply. Offers stable & clean current delivery under heavy load.
• Modular cable design: Modular cable design allows the user to pick and choose which cables they want to use, optimizing cable management and airflow inside the chassis. Flat cables allow for easier routing and bending inside the computer chassis during wire management.
• Hybrid LLC resonant Topology circuitry allows the HALE series to create highly efficient power supplies ranging from 550W-> 1000W.
• Full range Design from 100V – 250V with Active PFC.
• 100% Japanese Capacitors: High quality components for longer life time and better reliability.
• Latest CPU support for all the latest INTEL and AMD CPUs like Corei7, i5, AMD Phenom II X4, X3.
• Latest GPU support, ideal for latest DX11 GPUs and comes with 8pin and 8(6+2) pin PCI-E connectors.
• Large tower support: The Hale Series of power supplies have extended 8pin CPU connectors for wire management in large cases which have PSUs mounted at the bottom.
• Compliance with ATX 12V v2.2, EPS 12V v2.91, and SSI EPS 12V v2.92 Specifications.
• Environmentally Responsible: Consuming less than 1W during shut off status Complies with the newest EuP ( Energy-using Products) requirements and USA Energy star standards.
• Continuous Power: The HALE 90 series listed wattage is the continuous operating wattage.
• Keeping it safe: The HALE series offers over voltage, current, power, under voltage, and short circuit protection. The power supply will automatically shutdown to prevent any damage to your system or misuse.
• Warranty: 5 Years
ORDER NOW
Silverstone SST-ZM1350 Zeus Power Supply - 1350W @ £229.99 inc VAT
After a four year hiatus, SilverStone’s top of the line power supply series, Zeus, has finally returned. The all new Zeus ZM1350 retains excellent characteristics of its predecessors with continuous output of 1350W (1500W peak) rated for 24/7 operating at 50°C, ±1% regulation for exceptional stability, and careful selection of premium industrial grade components. Other aspects such as efficiency, modular cabling compatible with other SilverStone PSUs, and adjustable switches for multi/single rail, voltage tweak, and fan control are vastly improved to make this the most thought-after power supply for elites among IT professionals, PC power users, and overclockers.
Features:-
- 1350W continuous output and 1500W peak power at 50°C (60? with 1080W continuous)
- Low ripple & noise with strict ±1% voltage regulation
- Patented six / single +12V rails adjustable switch
- User-accessible +3.3V / +5V / +12V rails voltage adjustment pots
- 80 PLUS Silver certification with 80 PLUS Gold level efficiency at 230Vac
- Class-leading +12V rails combined loading up to 105A
- Industrial grade components
- Advanced 100% full cable management
- Long life dual ball bearing 80mm fan with speed control switch
Specification:-
- Model No. SST-ZM1350
- Max. DC Output 1350W (Peak 1500W)
- Color Black (scratch resistant and lead-free paint)
- Cooling System Single long life dual ball bearing 80mm fan
- Noise Level 20dBA-40dBA
- Dimension 150 mm (W) x 86 mm (H) x 230 mm (D)
- Weight 4.5kg
- Certification 80 PLUS Silver
Protection
- Over Current Protection
- Over Power Protection
- Under Voltage Protection
- Over Voltage Protection
- Short Circuit Protection
- No Load Protection
Connectors
- 1 x 24 / 20-Pin motherboard connector(500mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(700mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(500mm)
- 6 x 8 / 6-Pin PCIE connector(500mm)
- 2 x 8 / 6-Pin PCIE connector(500mm / 150mm)
- 16 x SATA connector (500mm / 150mm / 150mm / 150mm)
- 6 x 4-Pin Peripheral connector (500mm / 150mm / 150mm)
- 2 x 4-Pin Floppy connector (500mm / 150mm / 150mm / 150mm)
Was [£299.99] Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black @ £149.99 inc VAT
Leadex Platinum series PSU are 80+ Platinum certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Speciication:-
- Type: ATX
- Maximum Power: 1000W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Power supplies which can handle 3-4 VGA cards without issue, suitable for any hardcore gaming machine and a mining setup. :)
Gibbo, any chance of a better price on the EVGA P2 as another retailer has it in stock for £160inc, but I would prefer to stay loyal to OcUK :)
