I left mine switched off for 30 seconds, dunno if that will make a difference or not. If it doesn't, get on the phone to them and complain. I was about to call them but decided to try the reboot first and it worked (although probably only temporary).
Just wondering what affect the power levels have on the connection?
Mine are high judging by what people have put on here, but i have no issues as i know of.
That's too high. Post in the VM support forums and they'll send you out a tech. Mine looked just like yours a few days ago, and they sent out a tech who got networks to drop power down the whole street, as everyone was seeing broadband and tv problems with the power levels that high.
Managed to call VM at dinner and spent the whole hour on the phone, guy connected to my PC via remote desktop to apparently try a couple of thing (don't think he believed i was having problems) after spending 10 mins telling him how to open a command promt in windows 8 and that all drivers are up to date he ran several trace routes and speed tests which eventually showed an error on his computer ... engineer coming out later on this evening to hopefully sort my problem.
This but you can also buy your own attenuator (a -6 dbi one). Just remove the coaxial cable from the VM hub and put it on then connect it back up.
I thought VM were replacing the SH1 with the SH2? not free
Anyone any ideas how long VM take to fix the SNR issue? they should have gave you fault reference number
No the internal box is not for every device in the house - only for that room. There is one external box then they run along the external walls and then into the room it needs to go into (or up the wall then in if on the first floor for example).
