That is a modest OC tbh, considering it's a DCu II. Could the methodology be flawed here or a bad reading?
Really wanna see power consumption at 1300/1600...![]()
That does seem a bit high. Whats the stock voltage for a 290X, 1.25v? If so hes pumping nearly 1.4v through it so i guess its possible. Pretty sure Scotty & other titan owners have said titans pull a lot of watts at 1.4v. This will never get shown in reviews though as Nvidia lock voltage afaik and reviewers never use hacks/custom bios to get around it.
On Reference maybe, 780TI's, the Asus 290X is 3% more power hungry than the same Asus 780TI, or practically nothing.
vs the reference 290X its quite a different story. The Asus 290X sucks up 13% more than that reference 290X, so perhaps the Asus 290X is also running a bit more volts.
But i know what your saying, AMD are far from conservative with their volts on cards, it just means they are able to overclock well on stock volts, this approach makes them look more power hungry to the layman.
I have taken masses of volts off my GPU, and i do mean masses. yet i am still reaching 25% overclocks, its a joke
As well as that the core is at 1050 so that will increase power draw as well. Not sure if the memory is overclocked or not.
It's a bit rubbish in the overclocking department, nowhere near as quick as the four ref Asus 290Xs I have got lol.
"four ref Asus 290Xs I have"
Yeah, just, just go away with your stealth boasting, or donate one to some poor soul who needs one more than you need four, like me![]()
I need all four to knock NVidia off the top of the benching charts (when my case turns up and I can build the thing).![]()
Everyone here knows that if you had the choice between 4x290's of 4x7870's you'd pick the latter.
Pitcairn 4 life dawg.![]()
612w at 1185/1550 surely that cannot be right, something has to be wrong there as that is ridiculous. The thread says that is the card only and at 1.381v.
If that is really accurate (which I highly doubt) there will be no trifire going on then (without multiple PSU) with those cards 1800w + the rest of the system anyone.
Decent coolers certainly seemed to have tamed the beast though.
Which review was that?
I don't know why Hardware Canucks doesn't include power consumption results when overclocked/overvolted.bru said:It was the link that nelly posted up with that chart showing 612w usage in post 18 of this thread
http://www.overclock.net/t/1452037/hardwarecanucks-asus-r9-290x-directcu-ii-oc-review/130#post_21421107
I really do think there must be some amiss as that power usage seems ridiculous for a single card at only 1185 MHz.
http://www.overclock.net/t/1452037/...-290x-directcu-ii-oc-review/130#post_21421107
That will be whole system draw - take into account average efficency and remove an estimate amount for the rest of the system and you get about 400-450watt for the GPU itself which is more likely and still quite high.
