Making Windows 8 as slim as possible
10 May 2004
Middlesex
I've just bought a macbook (boo, hiss!) and need to install windows using bootcamp.
Now, I will only need to use it once in a blue moon but none the less it needs to be there for when I do need it.
I have a windows 7 full license and a Windows 8 upgrade license (I want to install 8).
I will use windows for the tweaking my phone (rooting, custom roms etc) and the odd game.
As I will be using it rarely I don't want to lose 40gbs of space to something I will not be using very often.
Is there any ways of cutting out a lot of fat and how large can I expect the install to be?
Thanks a lot.
What I was thinking was some sort of third party app that can skim the fat off of the install. There used to be apps for xp that could do this. I have tried googling but its mostly just old articles relating to xp.
disabling hibernate is probably the quickest "win" in terms of HDD space for Windows 7/8/8.1.
System restore etc is another, although clearly that has risks.
Windows 8 onwards is designed with 32GB tablets in mind. They've already reduced the footprint in 8.1 and I wouldn't bet against them trimming more fat themselves in future updates.
I wouldn't really entertain 7 for this purpose.
a bare naked 8.1 install only takes around 18-19GB. that's with a fixed pagefile of 2GB, system restore turned off and hibernation disabled.
windows 7 uses pretty much the same IIRC but it'll soon balloon if you run windows update.
I always turn all hibernate and system restore (I back up everything I need externally).
Is there a way of installing windows 8 without having to install 7 first with an upgrade license?
Do you not have to have an OS already installed for the upgrade version to work?
I installed Win8 when I had Win7 on the drive, but with it being on an SSD I wanted to secure erase the drive first but wasn't sure the upgrade version would work if I removed the previous OS installation via secure erase first - it would definitely be better if I could secure erase the drive first.
Read the link. :)
I have, especially this bit...
''Important: You can only install Windows 8 (clean install or upgrade install) using an upgrade license if you currently have a copy of Windows 8, Windows 7, Windows Vista, or Windows XP installed on the computer.''
I would like to be able to secure erase an SSD before I install the upgrade version of Win8, is that possible? :)
RT Se7en Lite and WinReducer 7 for Win7
WinReducer 8 for Win8
WinReducer 8.1 for Win 8.1
Not that I've used these myself. I would trust RT Se7en Lite more than the others seeing as it's Nlite.
Nlite for Win 8.x is coming soon.
It's probably legal info. You can do as you wish.
Winreducer will shrink the size of a windows iso, so you tick the boxes for what you want to keep, make the iso then install windows. A mate of mine managed to get win 8 x64 down to around 7 gig installed size with all games working, but he didn't include any network sharing, security centre, ease of access, help centre, hibernation, system restore and page file disabled and a few other useless windows programs were taken out, but it's the best way if you're real stingy with the space. Takes a lot of trial and error though, and you never really know if you'll need a vital file 6 months down the road, but your OS doesn't contain it.
The problem I've found with Windows 8 is that it seems to like to do a lot of background tasks which isn't always ideal on a less-powerful system. I've had ti disable various Windows Defender background tasks because after just a few minutes of idle time, it'd be chewing CPU cycles and thrashing the HDD. Not an issue on a PC really but quite noticeable on a laptop when suddenly the fans are having to go full-blast.
Install windows 8.1 upgrade, disable hibernation, system restore and page file, disable unnecessary windows features (pretty much all of them).
