Cannot un-spot 'read only' on ALL folders on a hard drive
7 Aug 2004
As title, I have googled this worry not !!!
Tried all the MS guides to make the SYSTEM own all files and folders, then tried doing all the following type commands from a admin command prompt:
C:\>attrib -r "F:\Test\*.*" /S /D
attrib -r +s F:\Test
NOTHING just remains 'spotted' (NOT ticked just a square spot), From reading M$ its by design, HOWEVER, I have checked EVERYTHING, all users, admins, authenticated users all have FULL control, I then checked ALL effective access lists and they were all green and ticked, YET I still cannot make any folder on the drive writeable...........I followed all the guides, currently the drive owner is 'SYSTEM' I have replaced all child object permission entries.......
Da hells I missed? :( I REALLY hope this isn't a weird bug, it randomly started doing it like 2 weeks
EDIT: I tried doing all child objects again and it threw up an error for 'f:System volume information' "Failed to enumerate objects in the container, Access is denied" which makes no sense as the entire drive is accessible in permissions?
HALP
Stop trying to change it.
Supposed to be like that. Are you actually able to read from one of the folders? I think so.
Windows 7 or 8?
There is a take ownership reg entry you can add
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shell\runas]
@="Take Ownership"
"NoWorkingDirectory"=""
[HKEY_CLASSES_ROOT\*\shell\runas\command]
@="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
"IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
[HKEY_CLASSES_ROOT\Directory\shell\runas]
@="Take Ownership"
[HKEY_CLASSES_ROOT\Directory\shell\runas\command]
@="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
"IsolatedCommand"="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
Save as a .reg file and import it.
Once done click on any folder and select take ownership.
EDIT - Just re-read your post and not sure if that is what you want.
Yes its pointless thought isnt it when I can't back up my light room catalogue as ANY folder is read only :rolleyes:
Windows 7 or 8?
Windows 8, thank you, yeah I need to write to folders because lightroom won't backup says write error
