- 1 Mar 2004
- Warwickshire
I don't agree with the hate for Pagid - are you sure they were genuine?
Mine always worked perfectly.
Copper grease. Grease with copper particles in it to aid it's anti seize properties.
Usually the FIXT stuff, but depends what ECP send me
"FIXT Multi-Purpose Copper Anti–Seize Grease is a high melting point, lead free copper based assembly compound which forms a dense protective coating that will not wash or burn off. Its anti-seize properties are particularly useful when assembly and dismantling occurs. FIXT Multi-Purpose Copper Anti–Seize Grease is ideal for protecting all metal against seizure, Leakage of oil and water, rust and corrosion, it can also help to prevent disc brake squeal if applied to caliper and BACK of disc pads"
Most of the time I drive sedate but my homes chav does come out every couple weeks. They were upgraded because it was driven much harder then (bmw takes all that brunt now)
100% genuine, I collected them myself over the counter at Euros
Gonna fit ate pads asap and report back
That level of wear doesn't even seem possible for 50k. The brakes are only tt sized so there will be lots of those driven just as sedate
yeah what clarkey says
What is the chepest price you can get for VW pads that actually come in a VW box?
Does the 312mm setup use the same Master Cylinder and Brake servo as the 288mm setup?
Is bias valve working too?
