Windforce 290X delivered - pics
Man of Honour
20 Sep 2006
Just had this delivered so thought I'd take some quick pics. I'm in a rush so not the best, and straight off the SLR.
The card is long, so make sure it fits your case before you order, it would probably struggle in mine if it had a rad at the bottom.
First impressions are good. I will run some benchmarks / mining with it later and get some figures up.
MilanoChris said:
Hell yeah, nice pics. Looks like it's on Gigabyte's own PCB, so I wonder if it's a custom PCB already?
Pump it up, lets see how far it overclocks. :D
Looks like all wind force, although my 780 GHz edition came with a backplate do they not do it on others?
Windforce coolers look so much better this time around, they looked and felt quite cheap on the 600/7000 series.
Running Heaven now at 1100/1300 (stock out of the box on this card was 1040/1250). The card is pretty silent, I can't hear it over my FT02 case fans, which are pretty silent. The true test will come when I run a miner on it to get the temps up.
How are the temps? That cooler does not like being oriented like that, same as my twin frozrs. Was cooler at stock but roasted when overvolted (680s)
Edit: tbh this version seems to have quite a small heatsink 'below' the core so it should be fine
First run Heaven as per the Heaven thread is 1394, max temp I saw was 85 with the fans quiet as a mouse. Fan settings in MSI Afterburner left alone.
My Titan with a mild overclock did 1531, in the same computer.
Nice, what's the stock voltages at idle/load.
Would be interesting to know what voltages needed to hit 1200MHz, that's if it can, and temps etc.
Maybe it can undervolt? :)
Just did a run at 1150, going for 1200 now with +100mv set. Getting some minor artifacting, so wouldn't run at 1200 with this card for gaming.
Well it failed that, so no good for 1200 at all. :( Even if I gave it more volts, it was artefacting however temps were fine. May just have a poor clocker. I'm only putting it this high to see what it can do anyway.
