Please can you tell me which one is the better option?
Get a dedicated sound card or use HDMI sound that connects to a receiver?
Thanks
Yes, it's worth it if you do a lot of gaming. I would just get the Z unless you really need the module. The two cards are the same spec. If you don't need a mic, then I would save even more money and get the OEM version.Sorry, forgot about this!!
Your system seems pretty good, I am not sure I would change anything.
Actually, saying that, I have a really good setup too, Pioneer SC-LX81 receiver and XTZ speakers and sub. The receiver is about the same as Yamaha you have. I am saying this because I did change, I bought the creative Z last year and have hooked it VIA analogue just like what you were thinking of doing.
I find it much better for gaming and way better when using headphones.
Music and movies, well, listen to both and see which you prefer.
So I am after coming full circleYes, it's worth it if you do a lot of gaming. I would just get the Z unless you really need the module. The two cards are the same spec. If you don't need a mic, then I would save even more money and get the OEM version.
Nice, maybe i should try it and see how it performs. When playing movies the receiver sometimes displays DTS, DD, DTS-MA, Dolby TrueHD etc when im playing those movies. What will happen via the the analogue setup we are talking about?
Your receiver won't display anything, only PCM. You will need the latest mpc-hc or some other software that decodes audio formats. I use MPC-HC and find it brilliant.
The receiver does display the formats because it's doing the decoding but on MPC-HC you need to enable it like i have shown below:
You asked me what would happen while playing movies if you changed to analogue inputs, would you still get the DTS and TrueHd etc on the display.
I answered you, You won't get those displayed if you are playing movies through analogue. And if you use passthrough on analogue inputs, like you have configured on MPC-HC, you won't get any sound at all or just static.
