EVGA GeForce GTX 780Ti Superclock ACX 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2884-KR) @ £569.99 inc VAT
The EVGA GeForce GTX 780 Ti is the best gaming GPU on the planet, delivering 25% more cores and exciting new technologies to take extreme gaming to a whole new level. This is pure performance accelerated, giving you the freedom to play every title at ultra settings and max resolutions on today's highest-definition displays.
Boost your gaming experience with a stunningly beautiful, quiet design. You get NVIDIA GPU Boost 2.0 for maximum clock speeds, PhysX and TXAA technologies for smooth, sharp graphics, and GeForce ShadowPlay to capture all your greatest gaming moments, automatically. Whether you're playing on stunning 4K monitors at extreme settings, or multiple monitors at 2560x1600, the GTX 780 Ti provides the horsepower to drive all your next-gen gaming visual experiences.
Of course, when paired up with EVGA's Award Winning ACX Cooling, you get reduced temperatures, silent operation, and best of all, unbelievable overclocking potential!
Specification
GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1006MHz
- Core Boost Clock: 1072MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Features
- MAX your overclocks with NVIDIA's Power Balancing
- A WHOPPING 2880 CUDA Cores (Fully enabled GK110)
- GPU Boost 2.0 Technology
Only £569.99 inc VAT.
ORDER NOW
_____
VTX3D Radeon R9 290 X-Edition 4096MB GDDR5 PCI-Express Graphics Card with Battlefield 4 Included @ £299.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification
Radeon R9 290
- GPU: Hawaii Pro
- Stream Processors: 2560
- Core Speed: 975MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Features
- DirectX 11.2 Support
- Open GL 4.2 Support
- Dolby TrueHD and DTS-HD Master Audio support
- Crossfire Support upto 4-way: Native software crossfire (No bridge required)
- Gaming @ 4k Resolutions (UltraHD)
- Synergy with next-gen game consoles (Mantle)
- Graphics Core Next (GCN) architecture - optimized from previous generation products
Only £299.99 inc VAT.
ORDER NOW
Specification
GeForce GTX 780Ti
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Features
ORDER NOW
_____
Specification
Radeon R9 290
- GPU: Hawaii Pro
- Warranty: 2yr
Features
ORDER NOW
seriously good deals though!
