Caporegime
- 8 Jan 2004
- Rutland
Moved into a new house a month and a bit ago, started decorating having very minimal past experience.
I've hit a problem with the first room. Tried to paint over the matt white emulsion on the walls with some Dulux matt. A few raised areas came up, put a second coat on to see if they'd be noticeable and more came up.
Small blisters around 5-10mm came up. When you poke them it all comes away leaving bare plaster board.
I've scraped all the worst areas back to plaster, sanded and put some Dulux plaster sealant then polyfilla on which does the trick for that area, but then when I wipe the walls down to paint bubbles come up in the untreated areas without fail.
Anyone come across this before? Am I just going to end up completely stripping the walls back to plaster?
