Motherbored for Intel Core i7 4930K
17 Aug 2010
Hi guys,
Whats a decent mobo, ram and cooler for the Intel Core i7 4930K, I want to get a good overclock. Price doesnt matter to much but nothing ridiculous.
Cheers!
EDIT : Also got an antec 300 case, do i need a bigger case?, if yes please spec! :)
YOUR BASKET
1 x Gigabyte X79-UP4 Intel X79 (Socket 2011) DDR3 Motherboard £209.99
1 x Kingston HyperX Beast 16GB (4x4GB) PC3-19200C11 2400MHz Quad Channel Kit (KHX24C11T3K4/16X) £161.99
1 x Thermalright Archon SB-E X2 CPU Cooler £59.99
Total : £441.56 (includes shipping : £8.00).
Ive used this board with a 3930K and can do 4.7GHz stable, the cooler will fit with the tall RAM or if you can fit a H100i or H110 in your case then even better:)
Remember that you may require a Sandybridge-E CPU to flash the BIOS in order to get your Ivybridge-E CPU to work with that board :)
Depends on the age of the board, if it was manufactured more recently then it may have a newer BIOS on it that supports IB-E out of the box.
To do the BIOS update (if needed) requires a SB-E CPU or places may offer this service.
Okay, thanks, any other suggestion of a board that will work out of the box?
