Your reply was to a point about property values.
I don't see how using a business leased line as an example of it being possible to put fibre in the ground and make money has any bearing on whether it's possible to do it at a consumer level. Obviously it's possible to make money offering a leased line service where you charge several thousand pounds for the install and then several hundred each month, but the last mile often goes over Openreach infrastructure anyway. Fluidata use FTTPoD where it's available to provide their services, one of the few companies involved in the trial.
Virgin Media / ntl went bankrupt several times trying to build out an infrastructure that didn't simply cherry-pick buildings that were easy to service, and even then they got to avoid doing much in the more rural areas.
With regards to your article from 2008, everyone has access to the infrastructure, here's the price list: http://www.openreach.co.uk/orpg/hom...6rNZujnCs99NbIKJZPD9hXYmiijxH6wr CQm97GZMyQ==
If it's so easy to build out your own nationwide fibre network then why is nobody trying?
Nobody has the right to dictate to BT what products they should be rolling out. If you want to build an expensive FTTC network to serve the entire population then you pay for it through taxation.
Anyone else can build their own national network, Ofcom can't stop this.
Please explain to me then why the quote I recieved for a leased line using fibre optic directly to my residential front door was less than the quote I recieved for BT to offer me FTTPoD?
62Mb/s, I can upload to FTP at 11Mb/s, Origin downloads at 90Mb/s...
Awesome, I see that this thread has totally derailed and become a different discussion entirely!
Just an update to my original post. The last cabinet in our village has been enabled for fibre (it has a fibre sticker on it, and the phones connected to it return as being enabled for 79Mbps), but as I originally suspected, we're not connected to that cabinet either. I have spoken with Zen, my provider, and they have nobody at BT that they can talk to about this exchange only issue. I just want to get some indication of plans for when it might be enabled for us. I have checked the coverage and basically the proper village has been totally excluded in the fibre upgrade, but new developments on the outskirts of the village have their own cabinets and they are eligible for an upgrade. This is just absolutely crazy.
Anyone have any idea how I would go about contacting BT about this?
The new developments got a fibre cabinet as they have to put a cabinet in anyway, so why put in one they would have to replace down the line? There is no profit in that.
Isnt this the same at every exchange area over the entire country including pockets of places such as central London? Ie, a nationwide issue, its not just your exchange area.
I would presume that you already have a decent sync rate via ADSL2+, too? Exchange only lines by nature are usually very short and as such serve customers which stand to benefit the least from FTTC services.
As it stands I don't think you will find that FTTC will be coming any time soon to exchange only areas, and when overcome it will be a nationwide issue.
Your line must also be fairly lengthy for you to be getting that sync rate, what an annoying situationSadly it is one which a hell of a lot of people are in.
