OCUK forum speed/responsiveness
just happened again :(
maybe they need more hamsters?
even though its only minor at times you do still get database errors
personally I think it looks badly upon the store, if I was a new customer that had this issue whilst visiting the forum for advice or link from Google
average jo:
"there forum runs slow & errors out, not looking at there store then"
i'm not moaning for it to be fixed. but an average Jo would think that.
It probably needs multiple servers behind a load balancer, which probably happens already.
The problem most likely is a mix of several things, a forum this size doesn't need a load balancer, it just needs updating.
1) Using ancient vb3 software. It might work now, but it wont always.
2) Using an ancient PHP version, they're running 5.2.10, which is 4 YEARS out of date.
3) Probably using a MySQL version just as old.
4) Using apache, again, probably just as old.
Fixes are simple... realy...
1) Should upgrade to modern forum software such as XenForo, which, some of the largest forums in the world now run. It's based on modern, up-to-date coding practises, utilising many features and optimisations that vb3 cannot.
2) Update to php 5.4.x, possibly even 5.x
3) Update MySQL to 5.5, or, if running an InnoDB-based forum, then Percona server.
4) Switch to a high speed web server such as LiteSpeed or Nginx.
Does get a bit sluggish at times, sure. That said, I doubt it's something they really want to invest a whole lot of money into upgrading.
It's actually pretty bad today. I blame the instant and moment spammers
All those threads just seem to be spam, should be closed temporarily at least to reduce load, as the problems have been going on for several months now.
Talkphotography.co.uk have moved over to Xenforo, it's quite nice :)
