AutoGlym Super Resin Polish (must have about 3 litres of this stuff now!)
AutoGlym Shampoo
AutoGlym Aqua Wax (quite looking forward to trying this out)
AutoGlym Glass Polish
All of the above are fantastic, I love the aqua wax when I really can't be bothered to treat with much else. Smells fantastic and can even go on the glass, plastic etc. Water beads well on it too.
Quick query I have regarding the SRP. How much do you apply to your pad? I've been applying a small pea shaped amount per panel but not sure if i'm using too much/too little.
It buffs off easy enough and looks shiny but can't seem to find a definitive guide.
In my experience it depends on the condition of the paintwork. I find it is much better to put less (about the same that you have described), buff off and then repeat at least twice more. Each time the resin will more effectively fill any scratches and will leave a much better finish.
I would highly recommend extra gloss protection or even better the HD wax. They are both fantastic at sealing the polished finish in and making it last much longer (we are talking months here). The extra gloss protection is much quicker to apply than the HD wax.
Should/can you use wax with egp?
