How many watts would you say would be needed? There seems to be little on the market between 850W and 1000W. Thanks
True, thanks, probs go for the rm850 that is on offer then
Compared to the other components in your system PSUs are one of the cheaper parts.
If you are in the position of having to buy a PSU I think it is better to spend a bit extra and get one that is bigger than you need at the moment. This could save you money further down the road when you start thinking about upgrading or overclocking.
I haven't overclocked the graphics cards, but then there's very little need to do so.
Short version, at stock settings you can run your rig with a good quality 750W, but if you want to overclock or have any kind of headroom, you're definitely looking at an 850W at minimum.
Your on the wrong forum![]()
I run a pair of 290s from an 850W Seasonic M12II and it copes fine, barely even gets warm.How many watts would you say would be needed? There seems to be little on the market between 850W and 1000W. Thanks
