Powercolor 290X PCS+ - custom PCB
22 Aug 2008
http://videocardz.com/48575/powercolor-shows-radeon-r9-290x-pcs
The release date and the final price were not yet disclosed. We believe it will hit retail next month.
http://wccftech.com/powercolor-previews-radeon-r9-290x-pcs-triple-fan-cooling-solution/
Display outputs include Dual-Link DVI, HDMI and a single full length Display port
PowerColor’s Radeon R9 290X PCS+ comes with a dual-slot shroud with triple fan cooling design which push air towards the central heatsink made up of two aluminum fin array blocks sitting on the Core, Memory and Power areas. The aluminum blocks are interconnected with six 8mm heatpipes which dissipate heat from the core and push it out of the card with the air supplied. From the size, the card certainly looks slightly taller than the stock solution
