- 12 Dec 2006
Hope everyone survived Xmas ok! I'm an infrequent user of the forum, but a loyal OC customer and need some help in deciding whether to splash out on a new pc or to upgrade the old one.
I last bought a PC in 2011 with the spec as follows:
Titan 8200i Spinosaur" Intel Core i5 2500K 3.30GHz with 4GB ram, a replaced SSD of 256GB and the existing graphics card. HIS ATI Radeon HD 6970 2048MB GDDR5 PCI-Express. The motherboard is the ASUS P8P67PRO and I use a 24" Dell monitor at 1900 x 1200.
I'm a casual gamer ...mainly shooters and have noticed that the PC is struggling with Crysis 3 on max settings
! I am thinking of upgrading it. What should I go for? Should I buy more RAM, another graphics card..a better processor etc?
I am fairly flexible on budget. If I were to buy a new PC, it would be for the base unit only and so a budget would be around £1000.
I welcome your advice...
! I am thinking of upgrading it. What should I go for? Should I buy more RAM, another graphics card..a better processor etc?I am fairly flexible on budget. If I were to buy a new PC, it would be for the base unit only and so a budget would be around £1000.
A great GPU and more RAM would do the trick.
