Corsair RM Series RM 850 cables
26 Nov 2013
Hereford
Hi everyone, I have just installed a Corsair RM Series RM 850 PSU into my case and hate the supplied cable set.
Could anyone please recommend an alternative cable set, one that is quite flexible.
Thanks.
Also those corsair ones may not fit the rm series. I have a blue set here for a hx unit and they don't fit other corsair psu's.
yes those cables fit the RM series, overclockers just havnt added RM in the compatibility list, look on corsairs site
•Series: AX Series, AXi Series, CXM Series, HX Series, RM Series, TXM Series •Watts: 1000, 1050, 1200, 430, 450, 500, 550, 600, 650, 750, 760, 850, 860
Ahh, fair enough. Though id still reccomend the bitfenix extension cables. I found them to be a lot more flexible than even the corsair cables.
Thanks OverKill that's what I should have done, thanks for checking if the Corsair kits were compatible. Those green ones should do the trick.
The 24 pin motherboard cable isn't included in that kit according to Corsair website. Not sure if OCUK sell it separate or not.
