Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC Licensed for Gran Turismo 6 @ £374.99 inc VAT
H.E.A.R.T. HALLEFFECT ACCURATE TECHNOLOGY™” is the name of the new technology developed by Thrustmaster to reproduce movements made on a product in games. It relies on magnetic – and not mechanical – 3D (HallEffect) sensors, placed in different locations according to the product in question. The precision made possible by the use of this technology is significantly higher than that provided by standard technologies. Another advantage of this system: by eliminating all friction, it guarantees zero mechanical wear, for permanent precision that won’t decrease over time. The level of precision is also enhanced by the absence of any dead zones: even the slightest movement made by the player results in a reaction. Actions in games are therefore more linear, smoother and without any untimely jolts.
- Authentic wheel: 30cm (12”) in diameter with brushed metal central spokes
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don’t move with the wheel)
- 17cm in height (for instant access along 1080°)
- Precision, Force Feedback & realistic angle of rotation
- New H.E.A.R.T Hall Effect AccuRate Technology™ on the wheel’s steering:
- Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
- Precision that won’t decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2”)
- Super-powerful, quick responding Force Feedback mechanism
- Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
- Realistic pedal set
- Unique design with your choice of 2 positions:
- Floor-mounted position (F1-style)
- Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable “Realistic Brake” mod)
- Included metal footrest with non-slip grating texture
Only £374.99 inc VAT.
ORDER NOW
_____
Roccat Isku FX Multicolour Gaming Keyboard @ £58.80 inc VAT
ROCCAT™ Talk® lets your compatible ROCCAT™ gaming devices join forces -- for amazing Set Bonus advantages that let you play faster, win more and enjoy a more intense game.
The ROCCAT™ Isku FX Multicolor Gaming Keyboard, the Kone XTD and the Kone Pure are the world's first devices to be connected with the ROCCAT™ Talk® protocol -- and they work great together.
For example, ROCCAT™ Talk® lets you take advantage of our exclusive Easy-Shift[+]™ technology like never before. Now you can use the Easy-Shift[+]™ key on your Isku FX to activate macros for both the keyboard and mouse – a one-stop short-cut that makes giving orders quicker and easier.
ROCCAT™ Talk® also lets you use our exclusive Easy-Aim technology to perfection when playing with the Isku FX and the Kone XTD or Kone Pure. When you need precise marksmanship in sniper mode, just press and hold a single Isku FX key and Easy-Aim will instantly optimize the DPI setting on your Kone XTD or Kone Pure. This unprecedented two-handed team marksmanship is the most convenient way ever to be the deadliest sniper in the game.
ROCCAT™ Talk® FX LET THE ACTION FLOW STRAIGHT TO YOUR ROCCAT™ DEVICE
The powerful ROCCAT™ Talk® protocol can also forge unprecedented software and hardware alliances thanks to a bold new feature called ROCCAT™ Talk® FX, which translates on-screen game action into exciting sensory effects on your gaming hardware – for a new level of intensity-packed play.
ROCCAT™ Talk® FX offers a wide range of amazing feature possibilities for compatible software and for enabled devices like the ROCCAT™ Isku FX, the Kone XTD, and the Kone Pure gaming mice. For example, with the ROCCAT™ Talk® FX Event Lighting feature, the lighting system on your device will activate in a certain color every time a corresponding in-game event occurs. Imagine getting hit with a fireball in your favorite RPG and having your Isku FX explode in glowing red bursts that dramatically mirror the on-screen attack! Or imagine getting shot with a poison-tipped arrow and having your mouse pulse in bursts of toxic green light that echo the nasty poison pumping through your veins! ROCCAT™ Talk® FX makes that kind of thrilling sensory gaming excitement a reality.
ROCCAT™ Talk® FX also makes possible additional ambient lighting effects that can greatly enhance the mood and intensity of your gameplay. Imagine running through a jungle in your favorite first-person shooter and having your gaming device emanate a dark green glow that brings that jungle feel right down to your desktop -- or swimming while your mouse glows in a shimmering ocean blue. And there's much more. ROCCAT™ Talk® FX's sensory messages can also be used to get important in-game notifications in a revolutionary new way. Imagine having your gaming hardware – not just the software -- alert you when your home base is under attack, or when production of an important building is finished. A groundbreaking way to better gaming.
HUNT YOUR PREY INSTEAD OF HUNTING FOR KEYS
The Isku FX is the only keyboard in the world to feature our groundbreaking Easy-Shift[+]™ technology, which offers you the wonder of 36 easily-customizable macros strategically positioned in 3 spots in the easy-to-find WASD zone. This means you can fire off orders without ever having to re-adjust your hand position – so you won’t have to take your eyes off the screen to look for keys. Simple and ingenious.
And because the Easy-Shift[+]™ key works just like the standard shift key, activating your macros is as simple as typing an uppercase letter.
The Easy-Shift[+]™ zone gives you an impressive 28 macros keys – including 8 dedicated keys that can be doubly programmed. Plus, the ability to instantly switch between 5 profiles lets you enjoy up to a whopping 180 macros – enough customization to meet even the most demanding warrior’s needs.
GET YOUR THUMBS INTO THE FIGHT
Are all your digits in? Now you can give your thumbs something useful to do instead of just hovering over the spacebar. Our ROCCAT scientists put three individually-programmable Thumbster macro keys right below the Isku FX’s spacebar -- each easily activated with a quick thumb strike. Perfect for casting a lightning-quick healing spell in the middle of a tough fight. Brilliant for a rapid weapon change. Think of your thumbs as two new eager allies. Thumbs up to that.
RECORD MACROS MID-ACTION
New enhanced Macro Live! technology makes in-game macro recording a joy. Simply hit the dedicated Macro Live! Recording button and let the handy new Sound Feedback tool talk you through the quick and easy recording process, step by step. You can program up to an amazing 500 actions for each of the 180 macros – giving you the freedom to lay down any orders you can dream up. And you won’t have to leave your game to do it.
RECORD MACROS AT YOUR LEISURE
If recording macros using a menu-based system is more your style then our world-famous Macro Manager software is just what
you want. The award-winning Macro Manager lets you record and fine-tune your macros with incredible precision -- and with intuitive ease thanks to a gorgeous and simple-to-use interface. The new Loop Function even lets you repeat your settings up to an incredible 255 times. And the internationally-adored program even comes with presets for top games and office apps -- so you can enjoy your favorites with no wait.
JUMP INTO THE FRAY RIGHT AWAY
Save your favorite settings – button configurations, lighting level, DPI preference, etc. — in 5 handy profile slots and activate each instantaneously with the simple press of a button – so you can game your way with speed and ease. You’ll always know which profile you’ve chosen thanks to 5 bright LED profile indicators. And with the clever Sound Feedback tool, the world-famous ROCCAT™ Voice will even tell you which profile you’ve selected. You can even set a profile for Windows which the Isku FX will automatically switch back to when you’ve finished gaming.
BE THE MASTER OF DARKNESS
Thanks to its off-white UV-coated keys and your choice of backlighting in 16.8 million colors and 6 adjustable brightness levels, the Isku FX makes it easy to always hit the right key -- even in low lighting. The Isku FX’s optimized illumination also means it’s perfect for avoiding eye strain during those long gaming sessions. Plus, you can program the Isku FX to automatically switch its lights off if you haven’t hit a key for a length of time of your choosing – great for when you want to take a break from your game. And did we mention Isku FX’s keyboard illumination simply looks awesome?
PAMPER YOUR WRISTS
The Isku FX’s Integrated Extra-Large Granular Wrist Rest acts like a sofa for your hands, providing perfect stability and comfort -- so you can avoid wrist fatigue even when gaming into the wee hours. Its advanced granular surface also enables fast, yet controlled, lateral movement – for optimized play even during the most hectic battles.
STAY LOCKED AND LOADED
Flip the Isku FX over (don’t worry, it won’t bite) and you’ll find 5 rubberized Non-Slip Gaming Boots and 2 rubberized Lock-Fast Gaming Feet. This means the Isku FX stays put -- even during the most intense play session. The retractable gaming feet also position the Isku at the ideal gaming angle of 5.90 degrees – ensuring the quickest key activation and best typing comfort possible.
BE IMPRESSED WITH EVERY PRESS
The Isku FX boasts medium height keys with fully-optimized key architecture, giving you a perfect striking surface and ideal keystroke response -- for finger action that feels right every time. The 1000Hz polling rate also ensures ultra-fast keyboard response with no lag, so your commands are carried out instantaneously. And advanced anti-ghosting technology means multiple keys can be depressed simultaneously -- making sure you can take full advantage of every complex command at your disposal.
CURE CABLE CHAOS
Your headset and mouse cables can now easily be tidied away using the handy cable channels under the Isku FX. And no cable mess means less to get in the way of you enjoying your game.
KNOW EXACTLY WHEN THE SPAWN ARRIVES
The Isku comes standard with the ingenious ROCCAT™ Timer, which gives you a handy audible countdown timer for any event you wish. Among other uses, you’ll always know exactly how long it’ll be before something re-spawns on the battlefield – valuable info you can exploit for a tactical advantage.
CONTROL YOUR MEDIA THE EASY WAY
The Isku FX features a row of 8 fully-configurable media keys, optimally positioned at the top of the keyboard -- for quick and easy access to 25 handy functions of your choice. It also features 12 programmable F keys, giving you a full range of customization options.
Don’t waste another gaming session with a keyboard designed for mortals. Be the legendary gamer you were born to be -- right now. Find your local Isku FX dealer.
- Illuminated keyboard with 123 keys
- Enhanced anti-ghosting capability
- 3 programmable Thumbster Keys (T1-T3)
- 5 programmable Macro Keys (M1-M5)
- 20 additional Macro Keys (Easy Zone)
- 5 Profile-Status LEDs
- 3 Status LEDs (Caps Lock, Easy Shift[+]™, Num Lock)
- 1000Hz polling rate, 1ms response time
- 2m USB cable
Only £58.80 inc VAT.
ORDER NOW
ORDER NOW
_____
PAMPER YOUR WRISTS
CURE CABLE CHAOS
- 2m USB cable
ORDER NOW
