Hi
I apologise in advance for this newbish question!
I turned on my PC yesterday but it failed to boot, I tried several times but it never once booted into windows, it never even reached the "hit delete key to load bios"?
Luckily, my wife has a PC too, so today I removed all the components from my PC, laid them out onto cardboard and hooked up the bare minimum peripherals needed to run my PC. I tried to start it with my current PSU, but again, it failed to boot. So I hooked up my wife's PSU, hit the power button and it started flawlessly.
Does this mean my current PSU is toast or could something else be a factor? I've tried clearing the CMOS via the MOBO's jumpers, removed the CMOS battery and tried different RAM configurations (like switching slots and installing one through to all four modules) etc but it always fails to boot with my old PSU?
Is there anything else I can try, any other component that can cause this kind of behaviour or is it definitely my damned PSU?
I've had the PSU since 2007 and I've never overclocked this setup.
I have an asus P5E3 deluxe MOBO
Intel Q9550 CPU
4 x 2Gb of DDR3 RAM (micron MT8JTF25664AZ-1G4D1)
An XFX 7870 GPU
Mushkin HP-580AP PSU
Prolimatech megahalems heatsink
Antech P160 case
Running windows 7 64bit ultimate edition
Thank you
Intel Q9550 CPU
An XFX 7870 GPU
Antech P160 case
Thank you
