LG 47LA660V - My first impressions
I also bought this 47" LG in the sales. Cracking price as according to the LG website, it has the same technical specification as the 690 version which is approx. £150 more than this Currys exclusive. I think the main difference between the 660 and 690, as far as I can ascertain, is the casing/bezel with the 690 being the more upmarket silver bezel of the 740 and the 660 having the bezel of the lower end 620.
I agree with Droolinggimp's excellent review. Impressed with the picture quality for both films and games. My main TV is a 2011 model 59" D6900 Samsung Plasma which is known for its very good picture quality. Although LED is not really comparable to plasma due to the over bright picture and colours compared to the natural picture of a plasma, I really liked this LG. The LED picture is better suited gaming than the plasma IMHO.
As regards 3D, although lower resolution, I much prefer the passive 3D of the LG to the Active 3D of the Samsung. It feels more comfortable and also gives a lot more depth to the picture but the acceptable viewing angle for 3D on the LG is narrower than the Samsung.
The SMART feature on the LG TVs is excellent. I think Samsung and LG are the leaders here. The LG has apps for all the main catch-up and streaming services in the UK which is convenient and handy.
One feature not mentioned yet is the voice recognition. Although it may seem as a bit of a gimmick it is seriously impressive. It can do a variety of functions using voice control including changing channel, checking the weather, finding out when a program will be on etc. If you have the TV, I highly recommend you give this feature a spin.
Yeah I forgot about the voice feature. I went into the internet browser and used the voice thing to search and it worked like a charm.. Not tried it yet for things like you mentioned.
Also I was impressed by the fact it plays videos from video one website on there too. My day off tomorrow and may give that a go again:eek::D
I've turned the voice function off on my Samsung F7000 - it just doesn't save anytime over using the remote
Motion control is much better; means you never need the remote control again :)
Careful with that Terminator 2 THX optimiser. I tried it on my ST50 and it wanted to completely crush the black levels.
Best download the AVS HD 709 black patterns and calibrate it with that.
I bought the same model (but in 42" size) for our flat. Such a big upgrade from our old 26" LCD el cheapo!
Need to sit down and sort out the picture settings as the TruVision makes it look a bit...odd. Almost as if everything is CGI.
Cinema/Movie Mode,
Sharpness at 0% or 1 notch from zero,
Brightness usually 50% or a bit under,
Contrast usually 50-80% depending on conditions,
Colour Temp on Warm
Colour itself needs to be adjusted with filters (best left at default if none available),
PN-R, Power Saving, Dynamic Contrast, Vivid Colour, TruMotion/Real Cinema/Whatever motion all Off.
Basic all-round settings for all TV's. But of course a proper calibration Blu-ray/DVD will be better.
Maccy..
Fancy posting the details, codecs etc of the mkv file. I will double check but as above, every one of my mkv files played absolutely no problem from my external drive before I moved to a server with plex..
Have you tried a firmware update?
Guys, posted this in another thread, but you have to get this app and have plex server installed in your streaming PC.
https://forums.plex.tv/index.php/topic/89004-simonjhogans-plex-client-for-lg-smart-tv/
Which version of tellys is this for? I note that the 2013 models came with plex pre-installed (It's called media link in the apps menu) - which works fine.
Can't get this app to install / run for the life in me! - my 2013 55LM760T just refuses to see it. I note LG used to sponsor Plex but now they've seemed to drop it so there's no client updates anymore which is why I'd like to use this version.
Whilst I do like plex its a tad slow for my liking - takes ages to bring up the metadata/thumbnails - or am I doing it wrong lol?
Ok, Video details -
H264-MPEG-4 AVC
1920x1082
F/R - 23.976
D/C Format - Planar 4:2:0 YUV
Audio details
MPEG AAC (mp4a)
48kHz
Depends on the model, medialink isn't plex as such. It is an inferior version of a DNLA player..
To install it, extract it to a usb stick within the folders
lgapps/installed/ Extract full folder here, eg 144675 or whatever folder name is with rar file..
Goto to my apps, then more and it should be there. You need to be logged in to your LG account to be able to use it.
The software will give you all the movie / tv show info etc.. Works very fast for me, I would say the same speed as media link when it isn't pulling media info from the plex server.
What firmware version you on mate, might need an update!
I'm on 04.22.07.
How are you trying to play it, through media link?
