I've decided on most things for my WC setup except the front 360 rad size.
So the case is the Corsair Carbide Air 540.
The roof rad is a 45mm thick 240mm rad (XT45 copper rad)
The two options for the front 360 rad
Really how much difference in performance can there be?
Anyone with a 30mm rad that can recommend using it?
- 60mm thick rad (fans mounted outside - no dust filter)
- 40mm thick rad (fans mounted inside - with dust filter)
- 30mm thick rad (reduces room taken up)
