Hi guys, got a friends amd 955BE system that needs repairing & fresh w7 install, but thought it might be a good time to upgrade to one of the new intels & newer pci-ex 3.0 mobos (as its for gaming and is 2-4 years old).
my research leads me to believe though that the new intels are almost no improvement over the old 2500k... so not a huge difference to the 955 for the huge £260+ it would cost?
http://www.ocaholic.ch/modules/smartsection/item.php?itemid=1158&page=14
current specs are...
amd 955 BE
(will update mobo model soon)
6gb DDR2 OCZ platinum
gtx 560ti
be quiet 550w psu
So... Do you guys think there will be much of a difference upgrading to i5 (or new amd) with pci-ex 3.0/DDR3 system now?
or hold out if theres anything new coming out soon from intel/amd that will make a bigger difference?
Also, do you know if SSDs still perform well on an old sata2 connection? I think maybe this will be a better upgrade for now lol.
amd 955 BE
gtx 560ti
be quiet 550w psu
