Gtx 760 or R9 270x
7 Dec 2013
Chester
I'm looking at these GPU's mainly for good price per performance can anyone help me
and put me on the right path
price im willing to put on a gpu £200
760 without a doubt over the r9 270x, it's generally faster across the board and can be had for as little as £172 if you shop around :)
Owned one myself and had it in SLi also. So if you add another later it would be a cheap route in the future to get more out of it.
I have a review I done posted here, if I can find it I'll link it.
My Review below, single vs SLi
http://forums.overclockers.co.uk/showthread.php?t=18527366&highlight=startername_jrodga2k5
Guru 3D review for comparison to r9 270x :)
http://www.guru3d.com/articles_pages/amd_radeon_r9_270_review,20.html
Owned one myself and had it in SLi also. So it would be a cheap route in the future to get more out of it.
Guru 3D review for comparison :) http://www.guru3d.com/articles_pages/amd_radeon_r9_270_review,20.html
what maker is the best for 760
I wouldn't say there generally is mate.
Most of the cheaper ones will have the stock cooler and you will pay an extra £10 upwards for different manufacturers with their own coolers.
I doubt you can really go for wrong in all honesty. EVGA is well respected around here in terms of their RMA and step up programs however you will pay a premium there.
If I was you I would opt for the cheapest price you can get one for :)
760 is better but costs more. That's about it, really :p
You can get the MSI Gaming OC 760 for under £200, that's the one I'd recommend :)
The EVGA, Gigabyte and ASUS are all solid too.
