Building 1st PC, advice and help on parts!
6 Jan 2014
Hi guys, i'm going to be building my first PC. I am obviously very excited but also nervous about making sure I have the right parts and hoping it will all work correctly. With the help of friends they have given me a list of parts (under my budget £600-£700) but I would appreciate any extra advice. Also after reading some additional information, I am nervous about my CPU cooler, as it is regarded as very 'big' and can have apparent problems when fitting in Memory (RAM). Any advice or help will be greatly appreciated! :D
BUILD (with manufacturing code, not sure if required)
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor (Haswell) Socket LGA1150 Processor (BX80646I54670K)
CPU Cooler: be quiet! Dark Rock Pro 2 67.8 CFM Fluid Dynamic Bearing CPU Cooler CPU Cooler Sockets 2011//1150/115x/1366/775 AMD (BK017)
Motherboard: ASRock Z87 PRO4 Intel Z87 (Socket 1150) DDR3 ATX
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-2133 Memory 240-pin DIMM (CMZ8GX3M2A2133C11B)
Storage: Western Digital Caviar Green 1TB 3.5" 5400RPM Internal Hard Drive (WD10EARS)
Video Card: Asus Radeon HD 7870 GHz Edition 2GB Video Card PCI-Express x16 (HD7870-DC2-2GD5-V2)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply
ATX12V / EPS12V (P1-550S-XXB9)
Case: Aerocool Xpredator X1 Midi Tower Case - White/Black (CA-000-AF)
Thanks again!
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £169.99
1 x Asus Radeon R9 270X DirectCUII TOP 2048MB GDDR5 PCI-Express Graphics Card £161.99
1 x Gigabyte G1.Sniper Z87 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £119.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW) £47.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £39.95
1 x Alpenföhn Matterhorn Pure Edition CPU Cooler £29.99
Total : £695.47 (includes shipping : £8.00).
- I've put a 270X in for the GPU. It's pretty much the same as a 7870, so get whichever is cheaper (assuming the one you listed is a non-reference ASUS)
- The motherboard isn't made by Asrock, which is a good start (their current-generation motherboards don't have the best reputation for build quality). It also has great onboard audio.
- PSU is gold-rated.
- RAM is faster and low profile
-The Dark Rock Pro 2 is the better cooler, but it is quite expensive given your budget.
- The HDD is on Today Only offer. 1TB for under £40! Makes me feel old.
YOUR BASKET
Very nice under £700 mate.
I'm assuming you need a dvd-drive and OS too?
Do you intend to OC in the future? otherwise you could step down a bit with the CPU and mobo and get SSD?
I don't believe I am getting a dvd-drive for now and yes I will be getting an OS. I would like to OC at a later time, but I am more than happy with the CPU and standard specs I initially stated. I have already purchased the Seagate Barracuda as suggested by 'Fulax' due to the one time offer, also the motherboard (z87) suggested I believe will be a good investment, thanks for the suggestions.
