Of course I've tried other motors, the 106 just seems to come out the cheapest unless I get a **** car![]()
Yep I remember I was getting quotes close to and over 2k etc when I first passed then 2 years later cheapest is £700![]()
I was trying to help - your OP sounds like you're clueless.
So you have found cheaper cars to insure? I'd recommend going with those, save throwing your money away on insurance at 17. A couple of years down the line there will be a world of difference.
I actually find that usually TPFT is actually more expensive than fully comp.
(they probably assume if you've got TPFT you don't care about your car, so more likely to crash into something)
