Some advice needed.
29 Sep 2007
Hi folks,
Currently in the final stages of buying and building my first rig. Just 3 pieces left to get and they are:
  • PSU
  • Case
  • Mobo
In my basket at the moment i have:
YOUR BASKET
1 x Gigabyte 990FXA-UD3 AMD 990FX (Socket AM3+) DDR3 Motherboard £104.99
1 x Corsair CS650M 650W Semi-Modular 80+ GOLD Certified Power Supply (CP-9020077-UK) £79.99
1 x Antec One Gaming Case - Black £49.99
Total : £249.07 (includes shipping : £11.75).
Ready and waiting i have:
8350, MSI r9 280x, G.Skill 8gb (2*4), Corsair h80i and an OEM lite-on dvd drive.
I'll be sticking in 3 Sata drives and more than likely an SSD.
So to cut a long story short, will the 650w PSU cover all that.
I was after a 750w but i don't have the funds on the credit card to cover it (it's only like £4 and won't clear in time) and the Mobo is this week only.
Apologies if that was a bit long winded and maybe even in the wrong area!
Thanks :P
What's your total budget? Also I wouldn't pick that PSU I would be looking at one of the Superflower or Sea Sonic
With the mobo and case i've got around £100 to play with but with shipping it takes it down to around £75-80. Not the biggest amount i know.
I had a look at the superflower and the seasonics. But Superflower ones in my range aren't modular and the seasonic ones are a bit too expensive i feel.
If i had the free shipping from forum posts it would be all good :p
You know i've had the 200r in my basket for about 3 days but today was when i decided against it. Great minds and all that :p
Ordered that setup.
Didn't even see that Danny but it might be too late as he already ordered it but you might be able to change it but I wouldn't go through too much hassle as the 650w will power your machine no problem.
Yeah, I didn't see Aird's post saying he'd ordered till I posted. And 650W will be fine.
D'oh!
Is it possible to change the order for future proofing and all that?
It's an easy task to swap something in orders, and getting a slightly more powerful PSU which will undergo a little less stress, for the same price, is a pretty good deal you can take advantage of.
http://www.overclockers.co.uk/contact.php
https://www.overclockers.co.uk/webnote.php
"Order Enquiry" section. Just give them the link and present price for the new item and state you want the original item replaced. OcUK are good sports. :)
