Hello all,
Just received a new case 'BitFenix Phenom MATX Cube Case - Midnight Black' for my birthday and started right away on striping the hardware out of my old Fractal Design.
Spec;
i7 2700k @ 4.8GHZ
Ballistix Elite 8GB Kit @ 1800Mhz
MAXIMUS IV GENE-Z/GEN3 Z68
680TI EVGA SC
750W OCZ PSU
Crucial M4 128GB SSD
1TB WD Green Edition
2x Venom 120mm Fans in the top of the case
Stock Intel Water cooler - Free from a friend
**Sorry for the poor quality images, will use my SLR to take better quality ones soon.
Purchased the ram, board and cpu back in 2012 and they have served my well so far so I do not plan to upgrade them just yet.
I purchased the GTX EVGA SC Titan back in October and then sold it, bought the 780TI for £600 as the performance, from what I saw, was better for cheaper. I realized that I would have to take a hit on the Memory size but I do plan to SLI the TI's and run surround.
First off I got the old gear out of the the Fractal and got it all nice and clean with new thermal compound and removed any dust from the board and fans/rad - Please excuse the towel, did not want to scratch the case while maneuvering it about.
Once I had it all laid out I proceeded to strip the Prodigy case to see what I had to work with, not much room.
I removed the useless CD/DVD holder and the bracket for the HDD/SSD's and put the motherboard standoffs into place to get an idea of cable routing.
Fitted the PSU, I love how this sits but could do with a modular one as there little room for decent cable management.
After routing the CPU Power cable under the chassis and screwing it all down I found it did not look too bad.
I then mounted the Intel Water Cooler but have since switched it around so the pipes are protruding from the bottom of the radiator not the top - will take a picture of this in due course.
Did a little cable management but was keen to get it turned on to make sure I had not broken anything with my dustbin lid hands.
Did not look too bad but was very excited to get some decent cable management done to make it look tidy.
Case Mods;
Swapped the side's around so the power button is on the left hand side of the case instead of the right.
Mounted the SSD behind the motherboard back plate to hide wires.
At this time I got it running and played a few rounds of BF3 - Ziba Tower and the CPU hit 58C which I think is pretty decent and the 680 hit 78c on 20% fan speed as there is two venom fans directly above it.
All in all I am pretty happy with this build but plan to add a second Ti and maybe a custom water loop. Thoughts, ideas and criticism welcome
Spec;
i7 2700k @ 4.8GHZ
680TI EVGA SC
750W OCZ PSU
Case Mods;
