- 11 Dec 2005
- Cheshire
The highlights of this week's deals are as following:
This week we are offering our all new Tech Labs Watercooled RAM from £69.98 inc VAT. Built in house and designed to run at ultra cool temperatures for maximum performance.
Get in the game with the SteelSeries Sensei RAW gaming mouse. Simple and elegant designed for the art of gaming. Yours for only £49.99 inc VAT.
Enjoy awesome quality sound courtesy of the Corsair Gaming Audio Series SP2500 High Power 2.1 system. Developing 232watts of power, the sound quality is outstanding! Only £184.99 inc VAT.
Want more? Our whole selection of deals HERE.
OcUK Tech Labs Watercooled Memory Kit - GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) @ £97.99 inc VAT
OcUK Tech Labs Watercooled Memory Kits are picked for reliability and overclocking performance. Each memory kit comes complete with a performance proven Watercooling solution from XSPC.
This set includes an XSPC memory waterblock, and two memory modules fitted with high performance XSPC heatsinks.
GeIL announces the launch of the new DDR3 Dragon RAM Series to be added to GeILs’ performance memory line of products. Not only does the Dragon RAM is tattooed with the GeIL dragon totem and crowned with two red LEDs as the dragon eyes, the PCB is eight layered instead of the usual six for maximum stability. As GeILs’ quality standard, the Dragon RAM will be reinforced with DBT – Die-hard Burn-in Technology for the highest quality assurance. Covering the most popular specifications of DDR3 today - 1333MHz and 1600Mhz, the Dragon RAM is the answer to an added value solution for the mainstream market.
Features:-
- PC3-12800 1600MHz CAS 11-11-11-28
- Designed for PC
- GeIL classic Dragon design
- 1.50v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge/Ivybridge or AMD AM3 based system
- Limited Lifetime Warranty
- Sandybridge/Ivybridge compatible
Only £97.99 inc VAT.
SteelSeries Sensei RAW Rubberised Gaming Mouse (62155) @ £49.99 inc VAT
Based off the most award-winning, critically acclaimed gaming mouse in history, the SteelSeries Sensei [RAW] is a tournament grade laser mouse that delivers only what you need to win. Powered by the SteelSeries Engine software suite, the mouse can be configured to meet your exact specifications including CPI, DCPI, lift distance, and button layout with intuitive drag and drop functionality. Featuring an ambidextrous, all-grip design, a premium-quality sensor, tournament-grade switches, 7 programmable buttons, brilliant white 3-zone illumination, high performance UPE material feet and SteelSeries Engine support, the SteelSeries Sensei [RAW] delivers on the essentials required to dominate the competition. Our “Winning is Everything” philosophy can be seen in every detail to simply deliver the best core technology - flip it over and see its guts. You know you want to.
- Cover Material: Plastic / Rubber
- Cord Length: 2m
- Number of Illumination Colors: 1
- Number of Illumination Zones: 3
- Connection Type: USB
- Number of Programmable Buttons: 7
- Scroll Wheel: Yes
- Number of Buttons: 8
- Frames per Second: 12000
- Inches per Second: 150
- Counts per Inch (CPI): 5700
Only £49.99 inc VAT.
ORDER NOW
Corsair Gaming Audio Series SP2500 High-Power 2.1 PC Speaker System - 232 Watts RMS @ £184.99 inc VAT
Since you have only one PC speaker system, you don’t want to make sacrifices. That’s why Corsair has created the SP2500.
At its heart are six Class D amplifiers driven by an ultra-efficient power supply. The 8” subwoofer driver is housed in a fourthorder bypass enclosure for clean, tight bass response that can seriously shake the room. The bi-amplified satellites use specially developed 3” drivers and custom-designed, ferrofluid-cooled 1” silk dome tweeters for detailed audio reproduction across the entire spectrum with great stereo imaging and a generous sweet spot. A programmable digital signal processor lets you craft the audio to your liking. It’s all under your command with the 1.8” (4.6cm) color display desktop controller.
- 232 Watts RMS of continuous power delivery through six Class D amplifiers
- 8” subwoofer with durable rubber surround in a fourth-order bandpass enclosure
- Bi-amplified satellites with 3” drivers and 1” ferrofluid-cooled silk dome tweeters
- Clean, high-fidelity audio reproduction with excellent stereo imaging
- Programmable digital signal processor for advanced dynamic audio processing
- Wired desktop controller with 1.8” (4.6cm) color TFT display and multi-lingual interface
Specification:
- Frequency response of 35Hz – 20kHz +- 3dB
- 232 Watts of total power (measured via FTC “RMS” method)
- Subwoofer: 18.1” x 10.2” x 11.7” (46 x 25.8 x 29.7cm) enclosure with fourth-order bandpass design for accurate bass reproduction
- Subwoofer: 8” subwoofer driver with durable rubber surround
- Subwoofer: Bridged dual 60 Watt class-D amplifiers with integrated DSP for 120W of power (measured via FTC “RMS” method)
- Subwoofer: Ultra-efficient integral power supply with 100V – 240V AC input
- Satellites: Bi-amplified, two-way design with detachable audio cables
- Satellites: 3” midrange drivers
- Satellites: 1” custom-designed, ferrofluid-cooled silk dome tweeters
- Satellites: 4.25” x 4.7” x 6.25” (10.8 x 12 x 15.9cm) enclosures with asymmetrical tweeter placement for superior stereo imaging
- I/O, Controls, and Programming: PC input on subwoofer
- I/O, Controls, and Programming: Dual 3.5mm auxiliary inputs (one on subwoofer, one on desktop controller)
- I/O, Controls, and Programming: 3.5mm headphone out with digital signal processing
- I/O, Controls, and Programming: Wired desktop controller with 1.8” (4.6cm) color display and multi-lingual interface
- I/O, Controls, and Programming: Digital signal processor with active crossover capability
- I/O, Controls, and Programming: Mod X™ theatrical audio processing for Blu-Ray and DVD audio that recreates the theatre experience
- I/O, Controls, and Programming: Dynamic DSP programs and EQ curves for late night listening, environment simulation, and optimal enjoyment of games, movies, and music
- Package Contents: x1 subwoofer, x2 satellites, x1 desktop controller with 6’ (1.8M) cable, 3.5mm to stereo RCA cable for PC input, 6’ (1.8m) satellite cables with ATX connectors, Power cable, User Guide
- Retail box dimensions: 22.75in L x 19.75in W x 15.75in H (57.8cm x 50cm x 40cm)
- Weight: 30.75 lb (13.9 kg)
ORDER NOW
Features:-
- Designed for PC
- 1.50v VDIMM
- Cord Length: 2m
- Scroll Wheel: Yes
ORDER NOW
Specification:
ORDER NOW
