Do you have and/or intend to use any other RAM with this 8GB? Or are you starting from scratch?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-369-CS&groupid=701&catid=8&subcat=1387
Nice RAM, nice timings, just make sure they'll fit with your CPU cooler due to height![]()
Nice thanks they were the ones I was looking at myself![]()
I was asked by a friend which RAM to buy, he is getting the
http://www.overclockers.co.uk/showproduct.php?prodid=MB-570-AS
I suggested these at first,
http://www.overclockers.co.uk/showproduct.php?prodid=MY-020-AR
Can I ask you, which would be better suited to that Asus board ?
Cheers.
Thats good RAM, his board can support faster RAM but it depends on budget really, I'm going to be using the faster version of the RAM you've listed for a new build soon![]()
Additional: I would stay around the 1600-2133MHz range with good timings and personally I'd look for RAM that runs on 1.50v at those speeds as well![]()
Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz aren't bad either
http://www.overclockers.co.uk/showproduct.php?prodid=MY-044-AR&tool=3
http://www.overclockers.co.uk/showproduct.php?prodid=MY-052-TG&groupid=701&catid=8&subcat=1387
a bargain,faster and cheaper
That review was with the higher binned c10 kit mate, theyre a bit more expensive.I'd go with these, and looking at a review pointed out by setter they managed to get 2666mhz out of 'em![]()
