Am I being thick?
Caporegime
24 Sep 2008
Essex innit!
Yeh, those are more for going into the rads/blocks then to another qdc with a compression fitting on or a barb fitting like this
http://www.overclockers.co.uk/showproduct.php?prodid=WC-136-KA&groupid=962&catid=1529&subcat=2305
But you would need one for the right size tubing.
To get the ones you have work directly with tubing, you would need a female to female g1/4
Adapter and a compression fitting or barb fitting...
Il check this again when I wake up as I too have just finished nights and my heads up my arse, but I think it's right =p
I looked for female to female but nothing...Male to male, no problem.
I think you are spot on and I just ordered the wrong bits :( Oh well, live and learn and thanks for the reply :)
Edit:
All sorted and found stock of female to female, so ordered 2 :) I was such a doughnut for ordering the wrong bits in the first place Doh!!!
They're confusing, I've got one set here which is a completely random size.
I'm using the 1/4 thread into the blocks and then the female tube fitting off the end
http://www.overclockers.co.uk/showproduct.php?prodid=WC-102-KA&groupid=962&catid=1529&subcat=2305
you are not the first to get male instead of female stuff... and you won't be the last :D i have a couple of connectors here for water that i got then headscratched at my own logic
:D
Not enough respect for your elders in this thread.... When I was a kid, we used to blah blah blah :D
@ Frosty - Looks good like that bud. Nice one mateeeeee.
Well parts should be here tomorrow and will add a couple of pics. It will look a bit silly with attachments on attachments (right up your street Petey :p) but will be nice to get the whole computer under water again and not just the CPU.
:D
In my defense, they were all necessary and I was never going for 'classy' :p
DONKEH!
:D
DONKEH!
Haha, fair play bruvva :D
Anyways, I couldn't be bothered to take pics and it needs a thorughly good clean, so pics will follow but I am very pleased with temps :)
Water cooling FTW!!!
Idle temps mind but happy days :)
