- 10 Apr 2006
- North West
One last question for the electrical boffins, would a dual cigarette socket adaptor be able to power both cameras from one fuse? Or do I need 2 female sockets going to 2 different fuses?
Problem with the one you posted dale is that I need any bulky parts to be at the end of the cable so I can put them by the fuse box. The power link ones have a block 3ft from the USB end which I wouldn't be able to tuck behind the roof liner.
Easiest solution looks to be use the existing cigarette socket power cable, route it to the internal fuse box and connect it to a fuse via female cigarette socket. Just need to figure out if 1 fuse and a dual female socket can handle 2 cameras or if I need two female sockets going to two fuses.
You also need Class 4 microSD cards, not Class 10. The Class 10 can cause issues.
The firmware version 20131202 fixed pretty much all the SDCard compatibility issues.
Thanks for the update - who did you buy them off in the UK?
Do you have any pics of your front and rear install? No reason other than interest![]()
