New EVGA sli bridge
Hi delpy, happy you finally got one
Yes, in that case you will need the 3way one so everythings fine :)
Feel free to post pictures of your rig with the bridge installed to the EVGA thread
Cheers
Hi Dominik ive sent you a PM as there seems to be a problem with my order as UPS have the incorrect address details?
The address on my order was incorrect too. I just had UPS phone me about it. €12 and 5 days to deliver a bridge.....sheesh.
Hi Dominik just to advise the 3way/2way EVGA sli bridge does not fit as per advised, I have my two classified in slot 1 and 3 of my ASUS Maximus exteme vi and the bridge does not fit :(
im going to needing a two way now to try
Can't you just use the 1st and 3rd red slots?
I know it will run gen 2, but that makes little to no difference with 2 cards.
Hi that is what I'm using at the moment but asked the question yesterday about putting my two cards into correct slots as per asus manual and I was told you always put two cards into slots 1 and 3?
According to the asus manual for two cards it should be 1st red and then the brown slot
Slot 1 and B2 to be exact :)
