- 11 Sep 2009
- France, Alsace
The Epic should outline "loosely" (like you said) the problem that exists.
The storyboards or points relate to the features and functionality that are required.
This is not how you will do it but the top level of what is wanted. It shouldn't be solutionized at this stage. You can then put a weighting (sometimes done with points, or poker cards etc. which I have a set of on my desk, unused, or just prioritized with the stakeholder/proj sponsor).
You then set the length of your sprints to what makes sense, but the idea of them being 2-4 weeks is not so that it can always change requirements, but you get something to the customer as quickly as possible, but also receive feedback as quickly as possible. If something has changed it can be brought up in a much more timely fashion than in a waterfall type approach.
