- 4 Nov 2002
- England - Leeds
Hi there, I was wondering if someone could please answer this questions as I'm interested in space/science too.
I was wondering how long it took for data to be transmitted from mars rovers to earth, I came across this article:
http://marsrover.nasa.gov/mission/comm_data.html
Which shows this:
Which answered my question, but then gave me a 2nd question which is why does the time data takes to transmit to earth fluctuate between 1.5 to 5 hours, I was wondering if radiation in space effects this or some other type of unknown forces? Solar system weather or mars weather etc?
EDIT: or in fact, after re-reading that passage I copied/pasted, have I miss read it, and it doesnt say how long it takes to get to earth at all? It it just saying if the mars rover were to send the data direct to earth it would be 1.5 to 5 hours...but it doesn't, it actually sends it direct to the orbiters which is "128,000 bits per second"? And therefore doesn't answer my original question of how long does it actually take to get to earth? In which case maybe the question should be how long does the orbiter take to send the data to earth? I'm confused lol...can someone please explain this to me lol
Thanks in advance.
Which shows this:
Communications With Earth
How Fast and How Much Data the Rovers Can Send Back
The data rate direct-to-Earth varies from about 12,000 bits per second to 3,500 bits per second (roughly a third as fast as a standard home modem). The data rate to the orbiters is a constant 128,000 bits per second (4 times faster than a home modem). An orbiter passes over the rover and is in the vicinity of the sky to communicate with the rovers for about eight minutes at a time, per sol. In that time, about 60 megabits of data (about 1/100 of a CD) can be transmitted to an orbiter. That same 60 megabits would take between 1.5 and 5 hours to transmit direct to Earth. The rovers can only transmit direct-to-Earth for at most three hours a day due to power and thermal limitations, even though Earth may be in view much longer.
Mars is rotating on its own axis so Mars often "turns its back" to Earth, taking the rover with it. The rover is turned out of the field of view of Earth and goes "dark", just like nighttime on Earth, when the sun goes out of the field of view of Earth at a certain location when the Earth turns its "back" to the sun. The orbiters can see Earth for about 2/3 of each orbit, or about 16 hours a day. They can send much more data direct-to-Earth than the rovers, not only because they can see Earth longer, but because they can operate their radio for much longer since their solar panels get light most of the time, and they have bigger antennas than the rovers.
Thanks in advance.
