- 6 Nov 2002
What headphones would you recommend? I would prefer some that go over the ear rather than in ear. They would be used to listen to music off my iPhone.
Sennheiser mm100 not cheap and discontinued, but soooo gooood!
I initially tried using bluetooth headphone whilst walking, but found as they were quite heavy around the earpieces, they weren't that comfortable. Find using an ipod shuffle (clipped to a t-shirt collar) and in-ear headphone the most comfortable solution.
Sony mar-zx300 basic £20 jobbies.
I'm the same can't stand in ear ones, they hurt, they fall out they're horrible.
Bluetooth would be nice.
But what I really want is some bone conducting Bluetooth ones. They were only available in Usa last time I checked, although I emailed and they were hopping to expand to uk at some point.
Now available but £75
http://www.amazon.co.uk/Aftershokz-...39&sr=8-3&keywords=bone+conduction+headphones
The only trouble with Bluetooth ones is battery life.
After seeing these I thought I would give them a try, they turned up this morning. I cannot believe how good they are, I was very sceptical to start with but after trying them out I was very impressed.
Thank you![]()
Thank you![]()
After reading some of the reviews it said in one that the sound was like listening to a transistor radio.
Others gave it a better a review but said the bass was poor and you had to keep adjusting them to get the 'sweet spot' so if you're running they must bob all over the place.
