- 8 Jan 2012
Hi All,
I know I recently asked for people input on a build. I went ahead and bought most of the things but have returned the giga oc board and 4770k cpu.
I will be going Ivy-E, I know that its overkill for my needs but I have the ability to build a system like this and have always wanted a top end PC.
This is my thoughts so far.
YOUR BASKET
2 x EVGA GeForce GTX 780 Classified "Dual BIOS" 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-3788-KR) £443.99 (£887.98)
1 x Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74930K) £439.99
1 x Asus Rampage IV Extreme Black Edition Intel X79 (Socket 2011) DDR3 Motherboard £419.99
1 x Corsair Obsidian 900D Super Tower Case (CC-9011022-WW) £299.99
1 x SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black (NESF-012) £199.99
1 x Kingston HyperX Beast 16GB (4x4GB) PC3-19200C11 2400MHz Quad Channel Kit (KHX24C11T3K4/16X) £161.99
2 x EK Water Blocks EK-FC780 GTX Classified - Nickel £89.99 (£179.98)
2 x EK Water Blocks EK-CoolStream PE 480 (Quad) £59.99 (£119.98)
3 x Monsoon 16/10mm (ID 3/8 OD 5/8) Free Center Compression Fitting Six Pack - Black Chrome £27.95 (£83.85)
6 x Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW) £23.99 (£143.94)
2 x EK Water Blocks EK-FC780 GTX Classified Backplate - Black £21.95 (£43.90)
1 x Bitspower Mini-Valve - Black Sparkle £16.98
4 x Koolance QDC (High Flow) No-Spill Shutoff, Male for 10mm x 16mm (3/8in x 5/8in) £10.49 (£41.96)
2 x Koolance QDC (High Flow) Shutoff Nozzle, Female for 10mm x 16mm (3/8in x 5/8in) £9.98 (£19.96)
1 x Bitspower Black Sparkle "Q" Fitting - 360 Degree Water Cooling Accessory £9.98
3 x Monsoon 16/10mm (OD 5/8) Rotary 90° - Black Chrome £8.69 (£26.07)
3 x Monsoon 16/10mm (OD 5/8) Rotary 45° - Black Chrome £8.69 (£26.07)
2 x Koolance QDC (High Flow) Shutoff Nozzle Female, Threaded G 1/4 £7.99 (£15.98)
5 x Primochill Primoflex Advanced Tubing 16/10 - Clear £5.99 (£29.95)
2 x Bitspower Dual G1/4" High Flow Fitting - Black Sparkle £4.99 (£9.98)
4 x XSPC M20 Fillcap for Reservoirs and Pumps (Black Chrome) £1.49 (£5.96)
Total : £3,204.64 (includes shipping : £16.85).
I can still upgrade my EVGA 780 classy via step-up to a 780ti reference design. Will end up going tri sli at some point probably May/June
I aslo will be using these things from my current pc
EK Supreme HF CPU Waterblock - Nickel Plexi
EK CoolStream RAD XTX (360)
OcUK Tech Lab - XSPC D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo
Would appreciate some thoughts on this. Will be a Black/Red/Black Chrome theme.
Many Thanks
Systemerror
YOUR BASKET
Many Thanks
Systemerror
