I dragged an old Corsair TX950W PSU out of storage about a week ago to use in a family members PC that required a bit more power. The PSU was fully functional when I put it away (It was used in conjunction with a second in a planned but not to be quadfire rig), however now it refuses to start.
When attached to a motherboard it supplies the basic power required for LED's to light up around the board indicating power is present,when the power button is pressed the system shows life (IE, fans spin) for just shy of a second and everything goes back as if the machine was shut down; Basic LED lights illuminated around the board.
After removing the PSU and trying to fire it with a jump starter, I get the same symptoms. The PSU fan goes for a second, then dies. Removing and replacing the jumper gives the same result again and again. Any ideas on this one?
