Here is a quick look and some tests of the new AMD Kaveri APU's, I have here the top end A10-7850K and lower A10-7700K.
In the box is your warranty guide, case sticker and small heatsink+fan with pre-applied paste.
Both these APU's are black editions and have an unlocked multiplier as denoted by the "K" in their model name and feature four new Steamroller cores and GCN IGP gfx.
A10-7700K specs,
Core speed - 3500MHz
Turbo speed -3800MHz
MMX instructions
SSE / Streaming SIMD Extensions
SSE2 / Streaming SIMD Extensions 2
SSE3 / Streaming SIMD Extensions 3
SSSE3 / Supplemental Streaming SIMD Extensions 3
SSE4 / SSE4.1 + SSE4.2 / Streaming SIMD Extensions 4
SSE4a
AES / Advanced Encryption Standard instructions
ABM / Advanced Bit Manipulation
AVX / Advanced Vector Extensions
BMI1 / Bit Manipulation instructions 1
F16C / 16-bit Floating-Point conversion instructions
FMA3 / 3-operand Fused Multiply-Add instructions
FMA4 / 4-operand Fused Multiply-Add instructions
TBM / Trailing Bit Manipulation instructions
XOP / eXtended Operations instructions
AMD64 / AMD 64-bit technology
EVP / Enhanced Virus Protection
Turbo Core 3.0 technology
Radeon R7 series IGP
Number of shader cores 384
Core speed 720MHz
A10-7850K
Core speed - 3700MHz
Turbo speed -4000MHz
MMX instructions
SSE4a
Number of shader cores 512
Core speed 720MHz
Below are CPU screenshots of these two new APU's and a previous generation A10-5800K (Trinity) APU which uses Piledriver cores at their maximum turbo frequency..
*Ignore the 0.4v Vcore of the A10-7700K as I think I grabbed that screen as it was about to throttle down under Cool 'n' Quiet.
Test setup.
A10-5800K
A10-7700K
A10-7850K
Kingston HyperX (2x4GB) 2400MHz RAM
Gigabyte A88X Sniper
Kingston HyperX 240GB SSD (RAID0)
Catalyst 13.35 beta17 drivers.
Windows 8.1
First test is CPU-Z at stock speeds.
Next up are some games,
BattleField 4,
•1920x1080 Medium Preset•1680x1050 Medium Preset
Hitman Absolution,
•1920x1080 High preset•1680x1050 Medium Preset
Bioshock Infinite,
•1920x1080 High Preset•1680x1050 Medium Preset
Tomb Raider,
One thing to note is that I can test Bioshock a thousand times and the max fps report varies constantly, the minimum and average fps remain constant.
Next are some synthetic benchmarks,
For Unigine Heaven4.0 and Valley I used the same settings as used in the forum threads found here,
http://forums.overclockers.co.uk/showthread.php?t=18487976
http://forums.overclockers.co.uk/showthread.php?t=18489026
Very stressful settings for a little APU to cope with.
Next is 3Dmark Firestrike, the full benchmark can be found here.
Next is Asus Realbench2.0 which can be found here.
X264 was ran, you can find this benchmark here.
PCMark 07,
Catzilla 1.1 was next up running at 720p from Here.
Cinebench R11.5
Cinebench R15
3D mark 11,
PC Mark08,
Overclocking.
Using the Snipers BIOS I managed to get the A10-7850K to a stable 4.4GHz by adding +0.054v to the Vcore and setting LLC to medium.
Of other note is that to get the A10-7700K to work perfectly with the RAM at 2400MHz it required +0.036v adding to the north bridge voltage, the A10-5800K and A10-7850K required no such adjustments.
Thanks to Ethermaster for the graphs and banner.
