Going 5-4 down in the 90th minute...
Winning 6-5 in the 93rd....![]()
When I've got the ball can I make people move forward in to space?
I've really got to practice a bit more, start looking at my mistakes, I noticed I get the ball I lose it in seconds, I try and pass I lose it. They get the ball they make like 15 passes before I intercept or they just run past me. I think a few hours of watching some youtube videos tomo. I normally do ok, normally lose in the 92nd min by the 100th cross finally going in -.-
L1 + X makes a player run forward after passing it.
Your playstyles would have worked a lot better in FIFA 13. It's not bad to pass backwards or sideways. From what I can remember you go forward, forward, forward and then try a hollywood pass at the end. Doing that will yield goals but it's not the most consistent way to create chances
. It also means that effectively you're not using your midfield in an attacking capacity.
Yea' the last FIFA I played and was really good at was FIFA 07-08, I was at some tournament for it at the NEC which was recorded and broadcasted on TV, XL something it was. Prize was only a few K I think but it had the WCG runner up and I smashed him... I'm still living in the past and need to adapt.
Cheers for the L1 + X thing mate, so many people do that to me and score but when I do it my guy starts dribbling on the ball and doesn't move much as L1 is close control isn't it? You're right my midfield has the ball for about 1 second before it's up front and you're right I just go Forward forward forward![]()
I'm still pretty good and the Hollywood ball seems to work more often then not for me
When are the toty midfielders available?
L1+X makes a pass and then the player who passed it runs forward. Bearing in mind this is PS4 we're talking about.
