New Build What do you think ?
What sort of pc controller do you recomend for playing games like crysis, call of duty, battlefield ? don't want to spend loads, as iv already gone over my budget.
Can anybody recommend a controller then for playing above game, plus fifa,witcher ect cheaper the better gone over budget.
Any of these will be fine.
YOUR BASKET
1 x Logitech Wireless Gamepad F710 (940-000142) £44.99
1 x Microsoft Xbox 360 Wireless Controller - PC / Xbox 360 (JR9-00010) £32.95
1 x Logitech Gamepad F310 (940-000138) £24.95
1 x Microsoft Xbox 360 Wired Controller - PC / Xbox 360 (52A-00005) £23.99
Total : £136.48 (includes shipping : £8.00).
Thanks, just bought all the components for the new build today, thanks everybody for your help, thank you and I'll keep you posted on the build in progress.
No haha can't wait to start building, all getting delivered Saturday. Are R9 280x graphics cards very good ? What should I get out off it graphical wise ?
I did my best in reading it, but I don't understand all the tech terms. Is it saying it's a decent graphics card ? In the review you posted above.
Yes it is a decent card.
We like the Gigabyte R9-280X WinDForce X3 OC edition. Most variables are right, the overall looks, the cooling and that nice the factory overclock. Our early sample however was rather noisy, once the GPU is under stress there's a lot of fan RPM, we do expect and hope to see this fixed with a BIOS update though. So aside from cooling added benefits are the factory overclock, the four outputs and overall just a really nice product that will guarantee you a pleasant gaming experience as these cards have plenty of juice to work with.
Update: Gigabyte is going to fit a new BIOS into the final mass production units that will lower noise levels.
When I install windows 8, should I install it on main hard drive or solid state drive ?
Install it on your ssd. Make sure ACHI is enabled in the Bios, it will show you how in the manual. Also donT connect your hdd until your OS is installed.
edit: Link for your mobo, use the drivers from here as they will be up to date. You also get the manual and have a read through it while waiting for your parts to come.
http://uk.msi.com/product/mb/Z87I.html
Paste is pre-applied to the bottom of the stock heatsink.
Disconnect the HDD cable while installing windows to prevent any random files being written to it.
I would just get your system up and running first, before thinking about overclocking. Then do a bit of research and get some idea as to how to overclock.
