Introducing the Raijintek Pallas 140mm & Zelos Low Profile CPU Coolers with an ultra low profile, they are designed to fit into even the smallest of chassis.
Both the Pallas and Zelos feature trademark German engineering that has defined Raijintek in the market. Signature Red and white fans adorn both CPU coolers adding a stylish flair amongst the uber efficient CPU Coolers.
Raijintek Zelos Low Profile CPU Cooler @ £14.99 inc VAT
Zelos, Raijintek’s new low profile cooler, is designed especially for low profile desktop. Total height - 44mm including 9015 PWM fan, Zelos is designed by German Engineer for presenting its greatly enhanced airflow and surface for heat dissipation. Zelos is nickel plating of the three heatpipes, and it also supports Intel and AMD modern CPU sockets and platforms.
- Low profile cooler – total height 44mm including 9015 PWM fan.
- Specially designed for most desktop system, especially low profile system.
- Non-Copper base design (C.D.C. - CPU Direct Contact)
- Enhanced airflow and surface for heat dissipation.
- 3 nickel plating heat-pipes
- Powerful 9015 PWM fan but silent, 1400RPM at 20dBA level
- Supports Intel & AMD modern CPU sockets and platforms.
- Intel socket LGA 1150/1156/1155 and AMD Socket FM1/FM2/FM2+/AM2/AM2+/AM3/AM3+.
Only £14.99 inc VAT.
ORDER NOW
Raijintek Pallas 140mm Low Profile CPU Cooler @ £31.99 inc VAT
PALLAS, Raijintek’s 140mm low profile CPU cooler, is designed for most desktop, especially for low profile desktop. Total height - 68mm including 14013 PWM fan, PALLAS is designed by German Engineer for presenting its greatly enhanced airflow and surface for heat dissipation. PALLAS is full heat-sink nickel plating and with super slim 14013 PWM fan. PALLAS also supports Intel and AMD modern CPU sockets and platforms.
Specifications:
- 140mm Low profile cooler – total height 68mm including 14013 PWM fan.
- Patented copper mirror base and full heat-sink nickel plating.
- 6pcs powerful 6mm heat-pipes
- Super slim and powerful 14013 PWM fan and silent level
- Intel socket LGA 775/1150/1155/1156/1366/2011 CPU (Core™ i3 / i5 / i7 CPU)
- AMD Socket FM1/FM2/FM2+/AM2/AM2+/AM3/AM3+ CPU
Only £31.99 inc VAT.
ORDER NOW
ORDER NOW
Specifications:
ORDER NOW
